Rotary cutter
/ Rotary cutter #1
dlay
East tn
kubota m7040/ jd 2155
Thinking about a 10 ft pull type rotary cutter, got good price on jd mx10, going to look at woods, does anyone have any recommendations?
/ Rotary cutter
Guess no one else uses bushogs???
/ Rotary cutter #3
We have been using a Woods DS1260 pull type for four years and used it in some really, really gnarly stuff and it has been a great cutter. We pull it with an M8540. I don't think you will have any problems puling it with your tractor. Woods is the predominant brand in my area and there isn't even a close dealer. Most use the 15 foot batwing though. 10 foot worked better for our needs.
/ Rotary cutter
I think that the 10 ft will be better for my needs also, I can buy the john deere mx10 for the same money, don't know which one to buy.
/ Rotary cutter #5
Both are good cutters, I thinkovrszd has an MX10 3PH model, so you might PM him, very helpful and knowledgeable. He uses an open station M9540 with his. He bought his used.
I am sure Bush Hog and others make good cutters, I just have no experience with them as I use Woods and Land Pride.
/ Rotary cutter #6
i don't have experience w/pull type mowers. naturally, you can get away w/a bigger mower that way compared to the 3pt lift models. if you are certain you only need the pull type, then just look at the HP pto requirements on the mower itself. think the pto hp on the 7040 is around 60-65. i have a 2 spindle 96" Rhino heavy duty lift type which is great for my 8540. in my case, lifting is a must. rhino is as heavy duty or more so than BH or Woods or land pride. they're all good in the heavy duty models. finish mowers are a whole different category & service application....in general i would stay away from them even on level rock free conditions. it always pays to study all the specs on each model before pulling the trigger. your 7040 owners manual will give you the max specs for various implements in terms of lift & size best of luck
/ Rotary cutter #7
I'd pass on that mx10. We had one that was nothing but a joke.
Both of the gear box spindles broke (at desperate times) sending the stump jumper and blades flying off. The biggest thing it ever mowed was a rose bush, no sapling trees or what have you. We basically were using it as a oversized lawn mower for clipping pasture.
It seems like there was a big fuss at the time over casting flaws in the spindles. It went to live with someone else after the second one broke.
The deck was pretty thin also, the slightest thump from underneath would knock the paint off the top.
/ Rotary cutter #8
Hi , I own a john deere HX10 pull type . I also own a woods BB840, 3pth I like both brands IMO . From what Ive read woods was one of if not the first to build a rotary cutter. ( I could be mistaken but I think I read this) regardless they build very good mowers. Ive have tried and proven this with mine , mowing up to 4" trees etc on very rough ground where I live . I also will back my jd Hx 10 , Its rated at heavy duty and it also has mowed very heavy brush ,filth etc.... I have no problems with either machine. I use the woods for backing up and around trees etc.... and for some of the really steep ground I mow on my farm. Its steep and full of slips etc ....... very rough. I pull these mowers with a Jd 5093e cab MFWD with a jd 553 FEL with fluid all 4 and rear wheel weights, loader on for extra weight and some occasional grubbing!. I hope this helps good luck to U.
/ Rotary cutter #9
"Ive have tried and proven this with mine , mowing up to 4" trees etc on very rough ground where I live" jdtractor
4" trees? now that would be something to see w/a rotary cutter :)
/ Rotary cutter #10
I have a WOODS DS1440 and LANDPRIDE RCR3596 pull-types both been great. The 12ft flat-deck WOODS in a pain,on un-level pasture not to dig in on one side or the other and to haul. The 8ft LP is good except for the deck not being flat and material build up on it but it feels small,not much the 7040 wont mow over with it. The 10ft would be a good size,if I had to do over would have got the 15ft batwing instead of the DS1440 or atleast have got the 12 batwing.
/ Rotary cutter #11
I have a JD 127 Gyramor. Its 60" and Iv mowed trees significantly larger than 4" going forward. I would think a 10' cutter would be sorta like a dual 127. Perhaps chassis integrity would be a big issue because it sticks out beyond the tractor wheels.
larry
/ Rotary cutter #12
Hi Spyderlk, When I say I have mowed 4" trees off , I mean here and there. I don't like to leave a few trees of small size in the middle of my fields if im mowing etc..... I will take them out if u no what I mean:). I usually push them over or if possible back up to cut them etc...... Most of my 4" work is done with my Woods Mower. Once in awhile I will come across a tree that I can take with my 10ft ,but usually its the 7ft. I can pick it up and move around easier. I will also say that most of the trees that Ive mowed are in the past, my fields now only have brush, and general small filth etc......but they are rough from slips & steep, hard mowing. Have a good one.
Ripper Tooth Excavator Attachment (A61567)
Ripper Tooth...
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
2016 Ford Escape SUV (A61569)
2016 Ford Escape...
BUNDLE OF 4"X RANDOM LENGTHS RED OAK FLOORING (A62131)
BUNDLE OF 4"X...
2022 Coyote Renegade Trailer (A63116)
2022 Coyote...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A62131)
UNUSED RAYTREE...
