Pallets in fields
   / Pallets in fields #1,881
I banged together a pressure treated pallet today. I'm not sure whether I should use it for hauling or experimentation.
   / Pallets in fields #1,883
Why not both?
I suppose I could do some experimental hauling.
Oh, and what nail pattern did you use + did any bend into special shapes?
16d common, galvinized. Some bent into special shapes, it wasn't intentional.
   / Pallets in fields #1,884
Did you feel the force ? Could an alien have been guiding you hand to bend certain nails into shapes ? The plot thickens.
   / Pallets in fields #1,885
That's what it was. Those bent nails had nothing to do with me being uncoordinated.
   / Pallets in fields #1,886
I felt the force this morning....
Then I went to the rest room!
   / Pallets in fields #1,889
If a pallet burns in the field, and one near it exudes the force, is any evidence of the event remaining for others to experience?
   / Pallets in fields #1,890
Did you inhale?
Silly question, obviously you did, deeply and multiple times. We are experiencing the event vicariously through your somewhat disjointed post. :laughing:
   / Pallets in fields #1,891
Did you inhale?
Au contraire, I was clearly on the other side of the burning pallet.
Disjointed? Surely you jest.
:D
   / Pallets in fields #1,893
From the thread: "Never thought I see the day 22 lr. ammo."
i'm not saying it's some weird x-files conspiracy. i'm saying there is an issue that is being downplayed a bit too much...
There is a huge wharehouse room under a corn field in Kansas.. the wharehouse is filled with .22LR cartridges...:D There might be some honeybees flying around too!... Just kidding..
You would think that we could see a few shells here and there sometime..
That could explain all those empty pallets in the Fields.
So maybe pallets mark the underground stashes of .22lr ammo......
Interesting.
   / Pallets in fields #1,894
Interesting.
Yep, ole Murph, has killed 2 birds with one rock. Now we know where all the .22 shells have went, and where them pallets come from.. it is the GUT, the Grand Unified Theory.
Einstein, ain't got nothing on ole Murpy! :D
   / Pallets in fields #1,895
It's strange they don't leave the ammo on the pallets when they put it in the warehouse.
   / Pallets in fields #1,896
Hey, this is mythical ammo, in a mythical place on mythical pallets... don't mess up a good theory here!:D
   / Pallets in fields #1,899
I don't get any jams when I use Mythical. Can't hit anything either.:confused3:
   / Pallets in fields #1,900
Hmmm. So there are secret/covert/hidden underground caches of .22 lr cartridges which are, so far as we can ascertain, only located in New Jersey.
On the one hand, that would account for the 500' distance between the pallet indicated bunkers = a blast zone buffer to prevent a cascading explosion should something go awry in one of the stashes.
On the other hand, leaving the pallets as a Bunker Access Portal Cover, indicating exactly where the hoard of ammunition is, defeats the purpose of "squirreling" the munitions in the first place.
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2003 International 9200I (A53317)
2003 International...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
