Quick Hitches front blade,broom,snow blower quick hitch
   / front blade,broom,snow blower quick hitch #11
I think most of this stuff is made by a company in Canada called Rad Technologies. I believe my Kubota snowblower will fit on a New Holland and Massey Ferguson quick hitch sub-frame and vice versa.
dsmiley. This is the link I wanted,Thanks. They may make different sizes of subframes for large and small hp.I'm going to try and enter a lineart drawing of the subframe and plow from my manual.lt190b
IMG_0001.jpgIMG_0002.jpgI'm having trouble loading images, maybe this time lt190b
   / front blade,broom,snow blower quick hitch #14
This is a line drawing from my subframe quick hitch manual and a rule measurement I took across the female opening of my mounted snow blower. It was from outside to outside and is probably within 1/8".
Hope this helps.
Dean
dsmiley Where/how did you find the Rad Tec link? I meased the opening on the blade, 11 3/4 x 2 1/2. The reason for my search is I want to be able to use my blade on a different tractor. Knowing that and wheather a subframe is built for a particular tractor will help in my shopping. lt190b
   / front blade,broom,snow blower quick hitch #16
Well, I was looking for a used front blade for my tractor and I figured that there might be one supplier of blades for a number of manufacturers so I wanted to know what color other blades might be. Then I noticed the similarities in snow blowers between some different makes and went searching for the manufacturer of my snow blower, a BX2750D. That's how a found RAD.
I agree with your thought that the size of the male and female parts probably change with tractor size. Mine is a scut, yours is larger.
Good luck.
   / front blade,broom,snow blower quick hitch #17
Hope this helps.
Dean
Hi dsmiley, I just came across this drawing and had to contac you. I just bought this setup salvage al brand new but it cam with no paper work and really not sure what I have exactly. Cold you please call me anytime that works for you at 913-915-7442 Greg If I don't answer, please leave message and I'll call right back. Thank you
2014 Chevrolet Traverse 2LT SUV (A55853)
2014 Chevrolet...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A55851)
Generac Yanmar...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
1988 Kenworth W900B Dump Truck with 3406B CAT (A57024)
1988 Kenworth...
