Loader Ford 3000 lower radiator nozzle flattened
/ Ford 3000 lower radiator nozzle flattened #1
jdharris5
Pittsburg, Kansas
Ford 3000, IH284
I have a Ford 3000 with front end loader(Ford 771) . When I purchased it a little over a year ago I noticed the radiator was leaking from the lower nozzle. I pulled the radiator and had a new nozzle installed at a radiator shop. It worked ok for a little while until I noticed the same thing was happening. The bottom of the nozzle was flattened. I was able to round it out without replacing and it again worked ok for a little while. The same thing has now happened again. I was using the loader to lift some fire wood and I noticed the radiator was again leaking from the lower nozzle which is flattened on the bottom. There is about 1" between the nozzle and the axle. I suppose the axle must hit the nozzle either when I go over a bump or perhaps lift something heavy. Any suggestions as to what I can do to stop this from happening will be appreciated. Thanks. JD
/ Ford 3000 lower radiator nozzle flattened #2
Look at what ever stops the axle from moving up too high. it may be missing a rubber bumper or shim or something. if nothing is missing I would make a spacer to stop the axle.
Thanks. I'll look at it more closely.
JD
/ Ford 3000 lower radiator nozzle flattened #4
Pivot pin might be wore out allowing axle to set to high in chassis. Something fairly important is out of wack for sure
I pulled the radiator today and the lower nozzle will need to be replace again. I inspected the front end as best I could. The radius rods seem to be ok. The 1.75" hollow pin is intact with some wear where it goes through the axle but the gap seemed to be less than 1/32". The loader is run off of the front pto so the pto shaft runs through the middle of the hollow 1.75" pin.
JD
/ Ford 3000 lower radiator nozzle flattened #7
You really need to lift the front axle off the ground to get a good read on what's wore. Watch the axle for movement up and down as you lift the tractor.
/ Ford 3000 lower radiator nozzle flattened #8
To lift the tractor set a jack under the nose of the tractor so as the axle will be suspended, or use the loader to lift front of the tractor off the ground
I used my jack to lift the tractor and examine the movement of the axle where it attaches to the tractor body. As I quickly raised the right wheel the axle seems to move maybe 1/8" at the center attachment. There is some wear at that point.
I was thinking of putting a 3/8" steel plate between the radiator and the radiator mounting holes. This would raise the radiator 3/8" and I would have the plate extend out below the lower radiator nozzle to provide some protection. Does this sound like a reasonable approach.
Thanks.
JD
2019 Sellick S80 (A60462)
2019 Sellick S80...
TRI PAC EVOLUTION APU (A60736)
TRI PAC EVOLUTION...
Giyi GY-CWG72 Quick Attach Curved Wood Grabber (A60463)
Giyi GY-CWG72...
2016 John Deer 5075E (A60462)
2016 John Deer...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
