BOBCAT CT 122 Hydraulic problem?
/ BOBCAT CT 122 Hydraulic problem? #1
hypogee
New York
Bobcat ct122
I have a 2009 Bobcat CT122 with 139 hours on it. I'm having an issue where The loader lifts/dumps/etc extremely slow empty and not at all with any load. Also having hesitation with the rear arms lifting and no downward pressure. I've let the tractor and oil warm up, well over an hour and no change, with rpm maxed when in use. All oil levels are full and all connections have been cleaned and checked for leaks. I bought this unit used and being not too familiar with Bobcat I'm looking for any help. Thanks for your time!!
/ BOBCAT CT 122 Hydraulic problem? #2
First thing I would do is check the hyd pressure to see if the pump and components can develop the advertised pressure.
If you can't develop the pressure, you have to find the cause.
Maybe pump, cyl seals, relief valve, etc.
/ BOBCAT CT 122 Hydraulic problem? #4
could be a pump. Remember that tractor is a Kioti so you can go through a Kioti dealer.
/ BOBCAT CT 122 Hydraulic problem? #5
The Dk35 doen't have down pressure or in fact does any other of the Kiotis on the 3 point.
Kubota ZG222 (A60462)
White 6182 12R Planter (A66285)
White 6182 12R...
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
KUBOTA KX057-5 EXCAVATOR (A65053)
KUBOTA KX057-5...
2007 FREIGHTLINER BUSINESS CLASS M2 SPREADER TRK (A64277)
2007 FREIGHTLINER...
2018 TAKEUCHI TL8 SKID STEER (A59914)
2018 TAKEUCHI TL8...
