loader question
/ loader question #1
smurphync
Member
granite falls nc
LS J2020
Just got my little tractor yesterday! We have got about r inches of snow and I wanted to clean up the driveway. I have the LL2100 loader on my tractor. I see in the manual where then loader has a float mode but I'm not quite understanding how to engage it. Any help would be appreciated! Thanks
/ loader question #2
Push the control fully forward.
/ loader question #3
Float is usually forward while pushing down (towards earth) on the grip, just one fluid motion.
Ralph
/ loader question #6
Can someone explain what the "float" mode on the loader accomplishes and when you would use it?
/ loader question
I'm new to the whole float deal in a loader. Actually this is the first tractor I've owned with a loader but I'll try to answer your question the way it was explained to me. The float mode allows you to "set" your bucket at a specific height and angle and the disengage it. It will "float" up and down over the terrain. I used it the other day while moving snow and it worked well. It didn't let the bucket dig in to the pavement as bad. I tried it both ways and it was useful
/ loader question #8
I have the R3039. Can you tell me how to place it in float? I will try it.
/ loader question #9
Push the stick all the way forward. You will feel it kind of click into float. It will stay there until you pull back to get out of float.
/ loader question #10
Thanks Boomer.. going to be away for a couple of days, but will try it out when I return.
/ loader question #11
Float basically eliminates the down pressure of the hydraulics on the bucket. You can still control the angle
of the bucket while in float, helps out while plowing snow etc, allows the bucket to "float" over the surface you are grading or scraping.
/ loader question #12
Very helpful when trying to level some dirt or gravel also. works even better if the bucket is full of whatever you are leveling since it adds weight.
208316 (A58375)
208316 (A58375)
70in Rock Bucket Skid Steer Attachment (A61572)
70in Rock Bucket...
LILLISTON 4R ROLLING CULTIVATOR (A63291)
LILLISTON 4R...
2019 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2019 ASV RT-25...
2014 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRACTOR (A59911)
2014 FREIGHTLINER...
JMR Tree Boom Skid Steer Attachment (A61572)
JMR Tree Boom Skid...
