Adding Kubota rear remotes
/ Adding Kubota rear remotes #21
I'm adding triple remotes to mine now. Got the stacks and levers assembled, plan to install on tractor this weekend.
Post with questions as you get into it. It doesn't seem that difficult to me but will know more when I start taking the tractor apart.
You'll kinda have double the work because you have to first disassemble your existing 2 remotes to add the 3rd. I'm not familiar with how your levers are set up, are they an integrated setup or independent? If they're integrated like mine youll need to remove the spacer and add your 3rd lever and linkage to the valve.
You will also need to take apart your stack to add the 3rd valve. Mine have Orings in between so you might consider replacing those while you have all 3 apart.
Then it's just bolting back together. Pretty easy so far...
Ymmv
J
/ Adding Kubota rear remotes #22
I don't have a trailer (or a large enough truck) and the closest dealer is 60 miles away, so before it even gets to the dealer it's $150 or more. That makes it worth an attempt. Besides I have all the confidence the experts here can guide me through it.
If I panic when I see the kits plan two - is to call a neighbor mechanic, plan three - call a cousin mechanic, plan four - call a Kubota mechanic who makes house calls, plan - five pay the $150 and remember the savings of not having to buy a larger trailer and truck, plan six - return the kits.
edit: looking at my plans I think I'll move plan four to plan two.
I have done these. Move plan four to plan one. Chalk expense up to part of the price of living.
You can do it yourself, however but the written word is never as good as being there in person with a couple of learning curves under your belt.
/ Adding Kubota rear remotes #23
Ymmv
J
Please take pictures and post as you assemble, thanks! I know you had a different Kubota but do you have the same kits: Part# L8303 and L8307
/ Adding Kubota rear remotes #24
My #s are a little different and more expensive unfortunately.
L8308 for the double acting valve and L8309 for the floaters. I've got 2 float and 1 DA.
L8348 for the 3rd lever.
Here is a pic of all 3 valves assembled along with the triple lever assembly.
/ Adding Kubota rear remotes #25
Thanks for the pic. The one I'm ordering I believe looks like this, the lever/hose part only, not the valve part.
Kubota L30 Series Double Acting Remote Hydraulic Control Valve Assembly | eBay
The valve I'm ordering L8303 does not have a float. The valve that does have a float is L8304. I just don't see why I would need a float for my use. What are you using your floats for. I have not ordered yet and can order a float valve instead.
/ Adding Kubota rear remotes #26
I'm primarily using float for my top and side links when attached to ground engaging equipment like a disc but there are other uses.
On the disc or rotary cutter, without float and a rigid 3pt mount, if the tractor begins to drive down a slope, the disc will lift in the back and you'll get an irregular depth. Same principal if you go up a hill, as the tractor angles up, the 3pt creates unnecessary bind on the tractor.
Same basic principals if I float my side link. When pulling my box blade or disc it will follow a sloped curve.
My belief is this will allow a 3pt disc to act much like a pull behind disc (assuming its heavy enough) but give me the 3pt benefit of being able to lift it and do a 180 degree turn for my smaller food plots.
Other uses. If you're running a hydraulic motor, rather than an abrupt stop, you can pop it in float and it will slow down gradually.
I figured I would rather have the option than not when the basic function is the same as a DA with the option to float.
I went with 1 DA incase there is a need for me to have constant flow to a log splitter or something. Will need to buggie it open because unfortunately a DA with detent wasn't available as a factory option.
There may be others and would love to hear what everyone else uses it for.
/ Adding Kubota rear remotes #27
The float valve (L8304) is only $39 more and it does seem like a good option for connecting to the top link when discing. So the float valves have that extension on the bottom for the detent float. Thanks.
/ Adding Kubota rear remotes #28
Get the float Don you will use it guaranteed.
Fred
/ Adding Kubota rear remotes #29
I think I know how float works and have it on my loader. It works great.
How would it apply in the OP's use? What are the advantages or disadvantages?
/ Adding Kubota rear remotes #30
Are these kits universal or tractor specific? I'd like to add a couple of rear remotes to my L4850 (and perhaps plumb one remote to the front for a bucket grapple)... where can I find the kit number or find the kit (I tried to google with no results)? Where are the levers mounted (on the fender)? Thanks in advance for informaiton ...
/ Adding Kubota rear remotes #31
tprochaz, the kits are not universal but they do fit several models - you will have to call the parts department to get your kit numbers and prices. The levers mount on different places on the different tractors.
These pics are on a Kubota L5030HST
The first picture shows an open slot for my third rear remote below the PTO to the left of the two levers.
The second picture is the two remote valves below and connected to the levers.
The third picture is the rear hydraulic connections. They are attached by a short hydraulic hose.
/ Adding Kubota rear remotes #32
The advertising Kubota dealers here allow access to Kubota parts books. I have looked up many parts.
If you are going to do this yourself it helps to have everything squeaky clean before you start. One little bit of dirt can really cause problems.
/ Adding Kubota rear remotes #33
Thanks for the additional information. I tried to find in several on-line part books but didtn't have any luck. So I did send a message yesterday to Messick's and asked if they have the kit and price. Have not heard back from them as of yet. Hopefully there is a kit, but since my tractor is over 20 years old (930 hrs) ... probably wasn't made like the more modern tractors to add options ... Tom
/ Adding Kubota rear remotes #34
/ Adding Kubota rear remotes #35
The older tractors had flat fenders and no specific slots. If that's your setup, forget the Kubota kit and add your own stackable remotes at a fraction of the price. There are many write ups of people doing it.
/ Adding Kubota rear remotes #36
Yes, that is my set up ... flat fenders and no slots. I'll do additional searches for how others have done it.
Thanks again for the help.
/ Adding Kubota rear remotes #37
Here's Messick's Kubota parts list. I have seen it everywhere and I think available on the Kubota website as well.
Kubota Parts | Full Service online retailer
EDIT----Here's from the Kubota website. I did not specifically search for your part but it seems everything is there.
https://www.kubota.com/part/parts.aspx
I searched both those sites and nothing came up. Then I search this site: http://www.colemanequip.com and the part came up so I could price it. But I still had to call the dealer to get the part number first.
For Kubota Model L5030HST
Regular valve kit Part # L8303 (or you can use floater valve kit part # L8304)
and you also need the lever kit Part # L8307
Part numbers are probably different if not a Lxx30 tractor model. Check with your dealer.
/ Adding Kubota rear remotes #38
Txdon ... not sure I understand. Is that the "kit" that is made for this tractor? Looks like just a valve. I also searched in the hydraulics forum section and there is a lot of info and and the electric over hydraulic for a front grapple sounds interesting. Still would like to have several remotes on the back and trying to digest all that is needed and how to do ... but I'll keep on reading as there is lot of information.
I kind of hijacted this thread ... sorry about that
/ Adding Kubota rear remotes #39
txdon--I'm sure you are putting the complete kit but for others reading this, the kit is the only way to go. The Kubota kit comes with generally complete instructions and all the parts. Even if you get in trouble, the instructions are enough to complete the job.
/ Adding Kubota rear remotes #40
I hijacked it so you can hijack it from me.
I edited the post above. For a Kubota tractor L5030HST the kit comes in two parts L8307 the lever/hose/connector kit and kit L8303 (Regular valve) OR you can substitute the regular valve with a floating valve that has a detent and that floating valve kit is L8304. The dealer mention a use for float valve kit would be if you had a batwing mower the wings would be on the float valves so they could follow the contour of the land. It was also mentioned in this thread that it could be used for a disc for the same reason. The valve in the float position would have no useful purpose for a grapple because you already have float on your FEL.
These are probably not the same number kits for your particular tractor. I cannot find a link anywhere to show you your part numbers. I had to call the parts supply of the Kubota dealer and he looked it up. Once I had the part numbers for the kits from the dealer I could check prices from Colman Equipment web site. http://www.colemanequip.com The Kubota dealers sites here on TBN did not have these part numbers listed and the searches came up "not found". The dealer did not have the kits in stock and would order them, for about the same price as Colman Equipment.
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
New/Unused Landhonor 20ft x 20ft Carport with Side Walls (A61166)
New/Unused...
2006 John Deere 325 Skid Steer (A63116)
2006 John Deere...
Pallet of Binders, Chains, and Equipment Slings (A61166)
Pallet of Binders...
30 Yard Dumper (A61166)
30 Yard Dumper...
2014 Chevrolet Cruze Sedan (A61569)
2014 Chevrolet...
