MorningViewStables
Those videos were really cool, but my guess is that is a very poor indication of what I can expect when I put a 4n1 bucket on a 50hp loader tractor.
I can second that! The 4in1 can be heavy! Mine is sized for the tractor, weighs 1,200lbs and requires 2,000lbs of ballast. It is mounted on a Heavy Duty loader and a 75hp MFWD tractor with AG tires.
Also, operator controls have a huge impact on the productivity of the 4in1. If you do not have button controls on hour hydraulic lift lever for the clam AND shuttle shift/powereverser transmission, you will perform very poorly with a 4-in-1. It is meant to be used in both directions and you need to learn to be able to make rapid changes operating the CLAM, loader lift and rotation simultaneously. You should consider Hydraulic Pump capacity as you will suffer performance if you are waiting on your hydraulics to re-position your clam, loader and bucket angle.
I have an appropriate machine to get the work out of the 4in1. Anything less and the 4in1 would be getting the work out of the machine (and operator) just to handle it. Choose your 4in1 wisely. If you are on using it as a hobby, your requirement thresholds for performance may differ.
