Adding Kubota rear remotes
/ Adding Kubota rear remotes #1
adamshatch
Upstate NY
Kubota Grand L4330 hst
Hello,
I would like to add rear remotes to my l4330. I was wondering how difficult a job this is. I am a fairly mechanical person and would like to save the install money if possible since the remotes are so dang expensive anyhow.
Thanks for your thoughts,
John
/ Adding Kubota rear remotes #2
There have been several posts over the last few years discussing this very subject (remotes for Grand L Kubotas). The Search function will help you find them.
However, assuming you want to go the Kubota factory route, here is what you need to order from your dealer to put one rear remote on an L4330 tractor. These prices may have gone up a few dollars however.
L8305 base kit $400
L8303 valve $200
If you want to add a second and/or third remote you buy these.
L8306 second position stacking kit $200
L8303 valve $200
L8307 third position stacking kit $200
L8303 valve $200
These are dealer installed options. Installation is not included in the prices.
You can install these yourself. The easiest way is to take off the right rear tire to gain better access. It's not hard and will take a couple of hours.
There are many posts here that describe the "roll your own" remote option whereby you purchase a stand alone valve with 1 to 3 spools (like a Prince SV) and plumb it in yourself. This will be a little cheaper but not as well integrated as you will have hoses going from here to there and you have to find a way to mount the valve on the ROPS or fender.
/ Adding Kubota rear remotes #3
As Mad Referee stated the job is not to difficult. Removal of the right rear tire (If tires are loaded be careful-very heavy)and fender makes the job easier. I originally went all Kubota, cylinders and valves. I found that the cylinders would not maintain equipment at a pre set position. Internal by-pass leakage I suspect. I then installed top and side link cylinder with pilot valves. Equipment stays at a pre set position now. I would not recommend the Kubota cylinders. If starting to do a new installation I would purchase the valves from Kubota and the cylinders from CCM. http://www.ccmachinery.com/TNT.htm. I would have saved money and been a much happier camper. I will probably use the other cylinders somewhere, someday but for now they are collecting dust. Just my thoughts.
/ Adding Kubota rear remotes #4
I added 2 rear remotes to my L4310. Had to take off some sheet metal like seat and toolbox to get to the area. Of course now that I've done it once I could do it without removing anything now.
Rich
NJ
/ Adding Kubota rear remotes #5
I just added the Kubota remote kit (Valve 1 only) and it was easy.
I only removed the panel in front of the seat (four bolts and the hydro speed knob). I did not remove the wheel or the seat or the tool box and I found access to be very easy. Installation is about an hour +-
I went with the Kubota part and if fit perfect, looks well made, includes EVERYTHING including mounts for the hoses and quick connects for your implement hoses. I have an L3010.
The kit is well priced and worth every penny. I ordered mine from Carver.
/ Adding Kubota rear remotes #6
Just to update this thread, the prices for these kits are through the roof now. The 2nd and 3rd valve are 700$ each, and I can't find a price for the lever and coupler kit.
/ Adding Kubota rear remotes #7
youd be money an time ahead to let the dealer install the remotes.
/ Adding Kubota rear remotes #8
How so? The only reason I see is if you want a very nice clean, OEM look, to your tractor. I added remotes, without knowing a darn thing when I started, at a fraction of what the dealer wanted. Yea, it's ugly and I had to learn a bunch, it took extra time, too... but I didn't have money to burn for the dealer, either.
I guess if I charged myself $90/hour to get the work done... :) it might have been a wash... :laughing:
/ Adding Kubota rear remotes #9
yes an those that do install their own remotes run the risk of really messing things up.an then it has to go to the shop.thus costing you double to fix.i can diagnose a tractors probs or equipment probs pretty quick.thus knowing what is wrong an how to fix it.but i let the shop do the repairs.
/ Adding Kubota rear remotes #10
Just an update to this old thread---the price pf Kubota remotes has declined as is now lower than a couple years back. I'm going to add a second set of rear remotes to an MX5100 and it's under $500 list price. I too recall it being very expensive a few years back so maybe Kubota figured out why so few were buying them.
Anyway, I'm going to look over the second remote kit first and see how difficult it looks. Last night I put the draft control kit on and it was a challenge, even though I had done it before, because the instructions were 20 years old and still has some very bad translation sentences.
/ Adding Kubota rear remotes #11
Hi six dogs...may I ask why you added draft control? I understand its for plowing is there other uses?
/ Adding Kubota rear remotes #12
Draft control on a light tractor with a piece of ground contacting equipment is a real plus. I use it with a landscape rake mostly on dirt but sometimes on sandy gravel with very small stones. To me, that's it's only real use on a smaller tractor and most people can get by fine without it.
As we know, if the tractor nose dips down, the implement in back will lift up and dump a line of dirt or gravel. Same thing if you hit a bump and the nose rises to cause the implement to dig in. Draft control, and some experience, allows the user to change way the implement behaves by causing the rear link to adjust the pressure on the implement to compensate for those dips and bumps.
I use it with an 8 ft landscape rake and can make a field or larger lawn as flat as a pancake with multiple passes and increasingly lighter feathering of the draft control. Some "washboard" ridges are hard to get out but you can do a surprisingly good job if you can go cross-direction. It works best if ground has had some rain on it and is a little hard or compacted.
Note, too that grass or debris or stones can complicate the issue. I will often till or work the ground, pack it super good (3000 lb Brillion) and let it harden up with a rain. Then the surface is somewhat flat with holes and bumps everywhere. The landscape rake will then fill the holes and scrape the humps by using draft control and some years of learning. I'll try to find some photos.
**By the way, if anyone wants to add draft control to the smaller L or MX Kubotas, start a thread and let me know. I have done it twice and there is a severe learning curve that could be made easier if they would have included more photos and updated the translation. I'm not done adjusting it yet and I have no idea what they are talking about on that page. The install took me over three hours and two were trying to understand the instructions--and I had done this before.
/ Adding Kubota rear remotes #16
Well, post some pics of your tractor and setup and explain how you use it. What is the intended use of the draft control? What kind of implements and what type of use ?
/ Adding Kubota rear remotes #18
Feb. 2014 updating. I am just about to order the parts for the third rear remote (two are already on the tractor) parts L8303 plus L8307 for my L5030HST (no cab). Price $473. I might be asking for assistance if the installation gets complicated.
/ Adding Kubota rear remotes #19
Hydraulics always scared me. Probably would cost very little to have the dealer install it. Just a thought.
/ Adding Kubota rear remotes #20
I don't have a trailer (or a large enough truck) and the closest dealer is 60 miles away, so before it even gets to the dealer it's $150 or more. That makes it worth an attempt. Besides I have all the confidence the experts here can guide me through it.
If I panic when I see the kits plan two - is to call a neighbor mechanic, plan three - call a cousin mechanic, plan four - call a Kubota mechanic who makes house calls, plan - five pay the $150 and remember the savings of not having to buy a larger trailer and truck, plan six - return the kits.
edit: looking at my plans I think I'll move plan four to plan two.
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
2016 EH Wachs Trav L Vac Hydro Vacuum Excavator Trailer (A61567)
2016 EH Wachs Trav...
2002 Lexus LS Sedan (A61569)
2002 Lexus LS...
PORTABLE SAND BLASTER (A62131)
PORTABLE SAND...
5ft 3 Point Hitch Rotary Cutter (A61166)
5ft 3 Point Hitch...
