Oil & Fuel Oil Bath Filter
   / Oil Bath Filter #1
Travis_R
Livingston Parish, LA
Yanmar YM2500
My MF231 has an oil bath filtration system for the air cleaner. I cleaned the oil cup and all the wire mesh this evening.
Ok, so the oil cup has 2 parts to it. Inner and outer cups... My question is should I fill up only the outer part of the oil cup, or both the outer and inner parts of the cup? The inner cup has 6 tiny holes all the way around it. I'm getting different opinions on this question from research.
Thanks
   / Oil Bath Filter #2
Fill it as the owners manual states. Cheaper than buying a new engine.
   / Oil Bath Filter
I completely agree. But my tractor is second hand and the pages are torn out of the original owner's manual that came with the tractor.
   / Oil Bath Filter #4
Are there oil fill marks on the cleaner? There was on my Ford.
   / Oil Bath Filter
Yes there is an "exact oil level" marking on the outside of the oil cup... But should I also fill the inner cup to that line too? If I fill the inner cup up with oil, the oil will be right below the 6 tiny holes that go around the inner cup.
   / Oil Bath Filter #6
I believe that line is just for the outer.
   / Oil Bath Filter #7
Fill up both parts to the oil fill line. Put the same weight of oil into it as what you put into engine.
   / Oil Bath Filter
How sure are you on this? I can't afford to ruin my engine. I just want to be sure.
Thank You
   / Oil Bath Filter #9
So that line IS for both sides? I had a oil bath in a ford truck never a tractor.
   / Oil Bath Filter #10
Iam postive. Have ran and still run tractors with oil bath air cleaner. Also have one on my old 3 ton grain truck. If anything your more likely to hurt the engine with too little oil than too much.
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
2015 Cadillac Escalade SUV (A50324)
2015 Cadillac...
2013 Acura ILX Sedan (A50324)
2013 Acura ILX...
1981 CASE 580D BACKHOE (A51242)
1981 CASE 580D...
JLG 1255 Telehandler (A52128)
JLG 1255...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52128)
2018 John Deere...
