Comparison BX2670 vs. B2320
/ BX2670 vs. B2320 #1
GreenBFarms
San Diego, CA
None yet but itchin' to get one!
Mornin'!
Was wondering if anybody had any opinions on the difference between these two machines (besides the stated HP and speed). They are pretty much the same in price...we have about 4 acres, 1 in lawn to mow (nothing fancy, just rough grass seed), and the other 2.5 for a sloped grove and dirt driveway to maintain. Thanks in advance!
/ BX2670 vs. B2320 #2
Not sure what a "sloped grove" is. Pretty sure we don't have them around here. The B series is bigger/heavier than the bx isn't it. That would get more work done. Also, regarding your other post, the r4s will be fine on your grass.
/ BX2670 vs. B2320 #3
I would go with the B. We have both a BX2660 and a B7500 each with a 60" mower deck. The B has a better ride and mows faster. The B also doesn't have the vulnerable transmission cooling fan.
Aaron Z
/ BX2670 vs. B2320 #4
Even though the BX is rated for more HP,the B2320 has the larger engine.Just something to consider.
/ BX2670 vs. B2320 #5
Look up posts by JOHNTHOMAS and bp fick, they have owned both types.
/ BX2670 vs. B2320 #6
The B has more ground clearance which is nice for maintenance or when you need it, also has bigger tires which I think look better.
/ BX2670 vs. B2320 #7
If the tractor's primary work will be lawn care or field mowing on steep slopes, I'd go with the BX.
By steep slope, I mean anything that is hard to push a wheel barrow full of soil up.
For working a food/vegetable plots, or working in deep snow, I'd go with the B.
The B sacrifices some stability for more ground clearance, so you need to decide which is more important for your particular needs.
/ BX2670 vs. B2320 #8
I believe that both tractors have the same engine, just set up differently to give more torque at less rpm on the B. We have the BX 2670 and looked at the B2320 as well but it came down to price and the pto operation. I did not want to have to keep putting in the clutch to dis engage the PTO on the B. The price on both was about a $400 difference but my dealer made a great deal for us on the BX. Both are good machines and as stated, the BX has a cooling fan, the B does not. This is a consideration if you intend to drive over/around piles of sticks or go in the woods alot. Sticks can take the blades right off the fan allowing the HST to overheat and possibly fail. Enjoy the shopping and make sure you test drive both machines, as well as the other orange, green and red. There are others as well that I may have missed.
/ BX2670 vs. B2320 #10
They're just different. Same engine, 1005 cu . Have owned 2 BX's and that same B2320.
The B2320 is taller with more ground clearance than the "paper stats" would indicate. The 3 speed trans isn't a huge advantage to me as how often did I run down the road in high gear? Not very often. The hydraulics on the B is noticeably faster. The bucket is also larger. Getting up into the driver's position is a harder step up for older guys with short legs. The 3 pt hardware is better on the B, but can be made better on both the B or the BX with aftermarket improvements. The transmission whine on the BX is more noticeable.
The BX is more nimble and has a lower center of gravity which is a plus to some users. The difference between the two machines is subtle but more than what meets the eye. You've got to put 100 hours on each of them to "feel" the difference in where each machine targeted. One isn't "better" than another, they are simply different.
Most of the work items and performance means there is an overlap of functionality between the two. If you're doing heavier field work or work in the woods, have more and heavier material handling to do, the B2320 would be a good choice. If you want a nifty, nimble, general all around solid performing yard/garden/snow tractor, the BX is a joy to operate.
/ BX2670 vs. B2320 #12
Can you elabroate on this, I have full size tractor implements that we used to run on a Ford 8N and a Ferguson 20. I realize that these are most likely too big for a BX series (looking) as the dealer explained the lift arms would fit if extended completly but would not get much lift out it as well for ground clearance.
/ BX2670 vs. B2320 #13
I am likely biased towards the B just because they are built more like a tractor. To start they have bigger tires, small tires in my opinion are a nuisance.
And then the engine in the BX is in backwards which puts the radiator in a difficult place to clean. and....JMHO
/ BX2670 vs. B2320 #14
Tried to resist.....but I can't.:laughing: :laughing: This is like saying a pickup truck is more like a automobile than a Corvette because it will haul more bales of hay or something along those lines.:cool2:
I've owned at least 5 different BXs and 4 Bs and the BX is just as much a working tractor as the Bs, just smaller and lower ground clearance. Owned one L3240 and it's no more a tractor than the BX or B even though it has/had bigger bucket, bigger tires and bigger 3ph arms! :2cents:
http://www.tractorbynet.com/forums/kubota-owning-operating/148830-b3200-bx2660-side-side-not-6.html
/ BX2670 vs. B2320 #15
like Bp and John have stated they are just dif. I have the B and like it a lot. Plenty of power either unit will get you job done for you. I like the large frame tractor as im a larger guy 6'4''. the B does great in field work and woods I cant speak to the BX.
/ BX2670 vs. B2320 #16
If your definition of a tractor is something that can do work than I quess I am saying that.:dance1:
/ BX2670 vs. B2320 #17
The comparison/debate is unnecessary to my mind. They're different. That's all I keep saying. My Ranger is different than my wife's little compact cube car thingy too. LOL I've got a lot of different chairs around the house. They're different. I could go on and on, but there's no point.
Just because they are both Kubotas, both cost about the same, both are intended to do some work. Just as a fancy F series mower or a skid steer might also be about the same price and all of them, all of them might have that same 1 liter Kubota diesel engine. You might find 4 or 5 different machines at a Kubota dealership that cost about $14-15K and have that same engine. But they're all different and targeted at different buyers. It's really that simple. Shoot, there's likely a Kubota RTV with roughly that price and possibly that same 1 liter Kubota diesel engine. So?
Buy what's right for you and your tasks. That's precisely why Kubota makes all these machines, with the same engine, at about the same price point. B, BX, F series, Skidsteer, RTV.
/ BX2670 vs. B2320 #18
The BX can handle standard Cat 1 stuff, but since the machine is lower, it can only pick it up so high. That's the reality. The BX comes with smaller tires and wheels. Does that make it "bad"? hahahaha The RTV also comes with smaller wheels and tires than an 18 wheeler and cannot carry anywhere near as much, does that make the RTV bad? Silliness.
Neither the B nor the BX have the lower arm features of Kubotas deluxe tractors. The lower arms on both adjust with turnbuckles. Ack!!! Both the B and the BX can benefit from having aftermarket lower arm adjusters adapted. My memory isn't good enough to remember the TBN member who makes and sells GREAT lower arm adjusters for the BX.
On the standard B series (the 20 series) you get budget features for the price point. These are not deluxe tractors. The Deluxe series B's come with nicer lower 3 pt arm adjusters. You can re-tro fit the deluxe version onto the standard B tractors and Ta Da!!! You'll like them a whole bunch. Cost is ???? 2 or 3 Ben Franklins I believe.
/ BX2670 vs. B2320 #19
Kubota turns the engine around on the BX for a reason. We may or may not like the side effects of what they did, but they had a reason.
On some Kubota products, they may even mount that same engine, wait for it… not forward, not backward, but heavens to Betsy!!! They may even mount it sideways!!! The horrors.
:laughing: They have reasons. Like it, don't like it, buy what you need and what you want. Buy Green for goodness sake. It's a free country. Mostly.
OK guys, I've had some fun with these posts. No offense intended whatsoever. Best regards
/ BX2670 vs. B2320 #20
BP and I are the "bigger isn't always better" guys along with a few others. BP had a BX went to a B and now back in "size" to a BX.
I've done the BX to B to L back to B to BX to B to BX to B dance and wasn't disappointed in any of them but my needs are maybe different than others and my needs have changed or I thought they had a few times and I'm sure they'll change again. I did have a B and BX, a few times, at the same time which was handy and then I've also thrown the RTV and 3 different F's in the dance.
I now have a B2620 FEL BH and believe I'd rather have a BX25 FEL BH but not enough to go trade today and maybe not even enough to go trade tomorrow.........but come warm spring weather when Barlows office is warmer than it is now with no or almost no heat..............I'm happy with what I have and come warmer weather I'll check this B7100 out that I bought a couple of months ago and haven't even started or moved it since it was parked in my storage building.:D :cool2:
(APPROX.20) UNUSED RAYSKY GROUND PROTECTION MATS (A62131)
(APPROX.20) UNUSED...
2016 Chevrolet Tahoe (MPV), VIN # 1GNSCBKC8GR280685 (A61165)
2016 Chevrolet...
2012 Chevy Impala Sedan (A61569)
2012 Chevy Impala...
2025 Quick Hitch Skid Steer Attachment (A61567)
2025 Quick Hitch...
2024 Bobcat T740 Track Loader (A63109)
2024 Bobcat T740...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2019 GENIE GS-1930...
