Bought a new tractor ... will be selling my R4047
/ Bought a new tractor ... will be selling my R4047 #1
TSO
Elite Member
SouthEast Michigan
Massey 1652 HST Cab
Well, as most of you have seen, I decided against all odds (and against my own past beliefs) to get a cab tractor. The cold, my aging, aching joints, and my snickering buddy (staying toasty warm in his cab) all led me to the decision... even the wife was on board with it! I know right?!
So anyhow, my search requirements required hydrostat, at least as much power as I already had with the R4047 (or close), a good loader, nice cab, affordability, at least 1 standard remote... all the basics. Of course my first avenue was to head to the LS dealer now that the R (now XR with the Tier4 engine) series had a cab available. My dealer offered me a fair trade-in price, and an "out-the-door" price of around $28k for the XR4046 HST Cab. Being a very big fan of my R4047 and LS in general I figured it would be an easy choice. Well, after playing with it, I wasn't really happy with it. I didn't like the overall fit/finish of the cab and I felt it wasn't as good as some of the other cabs I checked out. I didn't like where they moved the loader joystick to, or the parking brake lever. It came with a front wiper, but the rear wiper & radio would be extra. The tractor still comes with dual remotes & draft control, which are bonuses. But then came the engine. Now, it could have just been the cold, or that it was a brand-new-off-the-truck unit, but I wasn't very happy with the new Shibaura 46 horse Tier4 engine. It seemed very underpowered, especially compared to the Mitsubishi 47hp in my R4047. The hydraulics seemed slower too, and there was ALOT of hydro whine. The quietness of the hydro system in the R4047 is one of my absolute favorite things about this tractor, there is virtually no whine. I also wasn't especially pleased with the notion of working out any possible kinks of Tier4 as well. And finally, one of my ONLY complaints about my tractor, still hadn't been addressed in the new series: The loader. The loader height is too short for me and I run out of height, especially dump clearance, often. Since the loader hasn't changed at all for the new series, that was a definite drawback.
So I looked at the other contenders, which you might have seen in this thread: http://www.tractorbynet.com/forums/...27-apples-apples-comparisons-between-cab.html As you can see, the tractors are all pretty close. Some have clear advantages and/or disadvantages to the others when it comes to raw specs. I'll skip all of the fluff and get to brass tacks.
  • I ruled out Kubota because there were no new 4740's around. Even if there were, they would have been priced right out of the running.
  • Deere was ruled out for the same reason.
  • Bobcat was ruled out because you can't find any more new ones reasonably priced (white Kioti)
  • Mahindra was ruled out because of high pricing, and lack of options: No telescoping 3pt arms, no telescoping stabilizers, 1 standard remote, rear wiper, radio, draft all optional. However, the Mahindra clearly had the BEST loader of the bunch.
  • TYM was eventually ruled out, though reluctantly. The T503 is a nice package for a nice price. Clearly has a better loader than the LS and the same options. The cab was nicer too. The problem with the TYM was dealer support, or rather, lack of it. I was working on the phone with a dealer 2.5 hrs away. There was a closer dealer (45 mins) who practically carries/stocks NONE on the lot (they push Branson) and to be honest, it doesn't seem like they'll be handling TYM much longer. So, while I don't require a dealer right next door, 2.5 hrs is a bit too much for my comfort level.
  • Speaking of that, Branson was ruled out (although they put together a very nice package too) because their loader lift it only 1" higher than LS, and MUCH lower than the competition.
  • Kioti was right near the top. Good loader. Good options. Good price.
But ultimately, I ended up with the Massey 1648. I've always been a Massey fan, but they've always been too overpriced for my taste. The stars aligned and I found this one about 8.5 hours away in Central Wisconsin. Even though they wouldn't call it a dealer demo (it's a New 2012 model with under 10 hrs) I think that's what it is. But anyhow, I ended up getting it, out the door, for $30,800. They also had better financing rates through Agco (parent company) than I was getting on the other tractors thru AgriCredit. A couple points that helped make the decision:
  • This tractor has the DL130 loader, which has the 2nd highest lift height of the group (2" less than the Mahindra) and which is nearly 18" higher than the LS loader.
  • The hydraulic output is the best in the group, and 30% more capacity than my LS.
  • Operators area - the cab area was very comfortable & roomy, and I felt the best in the group, although the Kioti's area might have been about as roomy. The seat was/is VERY comfortable.
  • Cab-vision is very good, and there seems to be more glass / less hardware than the other cabs.
  • Auto-throttle - automatically matches the RPM's to the foot-pedal response, so you get the RPM's you need automatically, without using the hand throttle. I was surprised at how much I liked the feature. I think it's only Massey & Kubota that do this, and it really is nice. Unless you're doing loader work and want more pressure for the loader, you keep the RPM's practically at idle, and they increase as needed when you move.
  • Fit/Finish. I have to say, the Massey feels very well built. In my opinion, the best of the group. I'm sure someone will flame me for that, but the quality is top-notch.
But, I will say, the R4047 does feel more stable than this Massey. They weigh about the same (well, they would when comparing cab-to-cab) yet the center of gravity is much lower on the LS, as you'll see in the pics. Of the tractors I drove, the LS felt the most "planted."
You can also see in the pics that the tires are smaller on the Massey. Well, to be more accurate, the front tires are smaller (10x16.5 vs 12x16.5) and the rear tires are actually narrower but a tad taller (14.9x24 for the Massey VS 17.5Lx24 for the LS). I would have preferred the tires on the LS, but due to lack of availability, beggers could not be choosers. I could probably add the 12x16.5's to the front rims, but the rear rims would need to be changed to accommodate for the wider tires (the 17.5L ... wider & the "L" means low-profile). But, these tires are pretty common to Massey & Kioti, and many others ... people don't seem to complain about them, so I guess I'll give them a shot and learn to deal with them.
Anyhow, I'll be getting ready to sell my R4047 now. Just have to take off my home-made "canopy/cab" thing (easy bolt on/off --- sorry fellas, Gman already claimed it) and get her washed up. I'm just waiting for a dang day when it's not so frigid cold outside! My barn isn't heated, and it's hard to wash things when they immediately freeze! I just hope that the Massey will be as reliable & tough as the LS has been. Blue is still my favorite tractor color, but as I've said before, red is my close 2nd.
Pics: Note, with the loaders raised, the buckets were in the "level" then "dumped" positions.
/ Bought a new tractor ... will be selling my R4047 #2
Lookin Good! Good Luck with it. Everyone seems to be buying Cabs now.
/ Bought a new tractor ... will be selling my R4047 #3
Did they offer a trade in value?
/ Bought a new tractor ... will be selling my R4047 #5
Sitting here looking out my window at todays snowfall which I will have to tackle in the cold tomorrow, I can only imagine how warm and comfortable that new Massey would be. I am green with envy.
Congratulations on your new beautiful (and warm and comfy) machine.
Lol, all you need to do to get one is sign on the dotted line! That's all I needed to do anyhow. Of course, now I have to figure out how to pay for it 8-o
/ Bought a new tractor ... will be selling my R4047 #7
Yeah that would be a big problem at the moment, and the Kioti is payed for. The Canopy is great in the summer, but it don't do a whole lot for you in the winter... brrrrr
Yeah, I hear that. Congrats on having a paid-for machine. That's a nice thing to have! Actually, one of the ways I justified getting a new tractor again, is that I only just started making payments on the other one, so I'm looking at it that I practically leased the other one until getting this one. not sure if the logic is sound, but it makes sense to me at least! Lol
/ Bought a new tractor ... will be selling my R4047 #9
:thumbsup:Congrats on the new machine! Don't be a stranger on the LS Forum
Not to worry, the LS forum is a happening place... the Massey forum doesn't seem to move as much. Plus, I still have the LS until she sells
/ Bought a new tractor ... will be selling my R4047 #11
That's what I was gonna say, we are gonna miss you here in LS land. Wow what a difference in loader height! Nice machine.
/ Bought a new tractor ... will be selling my R4047 #12
congratulations.
Very nice machines, both of them.
I would really love to have a cab, but like James (kOua), my tractor is payed for and do not want/need the payments.
Good luck with it.
/ Bought a new tractor ... will be selling my R4047 #13
That loader on the Massey sure does get quite a bit taller than the loader on the LS.
/ Bought a new tractor ... will be selling my R4047 #14
TSO: congratulations on the new tractor! I had looked at the MF, the closest dealer is also a JD dealer and only had two small units, the next dealer was over 100 miles from me, nice tractor, but he wouldn't budge on price and had a used cab Kubota that he was real high on, 6 months later he still has 'em both! I took delivery of the XR4040 and while I really liked it, felt that it was short on power and while the dealer made me a smoking great deal ( he didn't have a 4046, and said it would be around June before he could get one unless he could another dealer to give one up) so I took the XR3037, I really like it on my small 10 acres, the cab is super, and with the less weight of the 4040 and even loaded rear tires, the turbo gives it a lot of power at 6300 feet elevation, I was plowing last Saturday and Sunday in shirt sleeves and it was below freezing outside! I was almost ready to buy a JD3520, this is about the same only a lot less $$, if I decide to get more power, I will look at the XR4046, a used JD4320 and I will look at the MF again. Thanks for your observations, enjoy the new tractor and especially the cab!!!
/ Bought a new tractor ... will be selling my R4047 #15
It looks like you made a nice step up by moving to the Massey. I know you'll love it, especially moving snow in all the cold temps you're having. I'm from the same neck of the woods, and although I haven't actually experienced the extremely cold snowy winter this year, my wife reminds me about almost everyday in an e-mail. I feel like a complaint department. I also am going from a completely paid for tractor to a 5 year monthly payment when I move up to a cab from my OS 4720. Don't know if it's just me, but I love the feeling of actually owning something rather than feeling like a renter, but at least I'll be moving up to a cab. Enjoy your new machine, and keep the pics coming.
/ Bought a new tractor ... will be selling my R4047 #16
I was wondering about the new engines in the LS if they would be as nice and as powerful as the Mitsubishi's are now I guess I know. The spec's just seem less. I wonder why the hydro tranny wined more could it be because the engine is quieter or did they actually change the trany too?
/ Bought a new tractor ... will be selling my R4047 #17
I though about you and your big pretty (and warm) Massey today as I was out plowing our road and driveway.
I don't see why you could not have brought it over to let me "see" it!
Man it was cold today.
I still don't want to pass total judgement after just one test drive, it still could've been the cold, or God knows what else... I don't think they put in a different tranny. I think that Mitsu S4QL is an all star engine, it's about 15% larger (in displacement) than the Shibaura, and even my Iseki... and I've read is rated for higher HP in different applications also. This Massey is not particularly quiet (hydro whine) either, but maybe I was just spoiled by the lack of whine on the R4047.
Interesting note, the Massey seems to put more power to the ground in HIGH range, but the LS seems a little stronger in MED range. Haven't used LOW range yet to compare.
And James, as much as I hate admitting when I'm wrong, I should have gotten a cab a while ago. I was pushing snow for about 90 mins combined today. Was basically just in jeans & t-shirt, had to open the vents at times as well! Obviously, on an open station you can bundle up and stay fine, but that doesn't do much for the blowing snow, or when you feel cold to the core when you're done.
I debated back and forth whether or not I should complete my own home made cab instead of buying a factory one. After experiencing how well the factory heat works, especially with keeping the windows free and clear, I think in the end it will be money well spent.
/ Bought a new tractor ... will be selling my R4047 #19
I though about you and your big pretty (and warm) Massey today as I was out plowing our road and driveway. I don't see why you could not have brought it over to let me "see" it! Man it was cold today.
what you just said. I just got in after a long day of work, cleared driveway w bx. Was cold but not as cold as snowblowing:)! I would have loved to check out that cab....... Just to make sure heat and wipers, radio work you know:)
/ Bought a new tractor ... will be selling my R4047 #20
Oh and btw congrats on your new tractor!!!:)
2023 Nissan Altima Sedan (A61569)
2023 Nissan Altima...
CASE 588H ROUGH TERRAIN FORKLIFT (A62129)
CASE 588H ROUGH...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
2021 Deere 331G (A53317)
2021 Deere 331G...
2018 Volvo VNL 760 T/A Sleeper Cab Truck Tractor (A61568)
2018 Volvo VNL 760...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
