Bought a new tractor ... will be selling my R4047
   / Bought a new tractor ... will be selling my R4047 #42
thanks, I want to tap into the beacon setup, they are a special connector that is only available with the beacon for $250 so I bought an LED strobe for $50 and want to hard wire it in.
I didn't open it up, the tech had it open to check all of the connections and to install the radio, he showed me that there are 4 bolts holding it down,nits hinged at the back and on the right rear there is a substantial prop today to hold it up, I wouldn't open it outside in case the wind would get it, it is heavy as it's a blue cover over a metal cover and then there is a metal base where all of the HVAC stuff bus, the headliner that you see inside the cab, is a cover over the metal pan, I believe all of this is part of the certified ROPS
   / Bought a new tractor ... will be selling my R4047 #43
Amazing the difference in loaders.
Right, particularly considering the lift capacity it has at that height. You sure would have to be careful of your stability with the loader up high. Very nice tractor.
gps trailers (A56859)
2006 CATERPILLAR 320CL EXCAVATOR (A59823)
2006 CATERPILLAR...
2352 (A60432)
2352 (A60432)
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
17102 (A56859)
17102 (A56859)
