It finally happened - how long did yours last???
   / It finally happened - how long did yours last??? #11
When I traded in my B7500, it had 8 years, and was starting great the day I traded it in.
   / It finally happened - how long did yours last??? #12
Kinda off topic but have you guys ever used those maintenance chargers. The trickle chargers you put on like a boat battery in the winter when you store your boat. Ive ruined 2 batteries using those things. What do you guys do when putting up a battery for the winter.
   / It finally happened - how long did yours last??? #13
Put a new battery on the Ford 2600 last spring. It was 10 years old. I keep a battery tender (maintainer/charger) on it during the winter. The other two tractors see some use all year long.
I think that every once in a while you just get lucky. Other times, not so much. The TN70A had to have a new battery when it was just 3 years old.
   / It finally happened - how long did yours last??? #14
11 years on the original battery in my JD Lt180 mower......no maintenance charger ever. Check the water and clean the posts......she still is going strong.:thumbsup:
   / It finally happened - how long did yours last??? #15
I've had good luck with DuView attachment 358376View attachment 358377ralast Gold batteries. Of the two I purchased back in the late 90's, one lasted about ten years and the other is still in service (14 years +). I think I wrecked the ten-year-old one by too-rough cross country driving - shorted a cell by stirring up the sediment. The 14 year old one is in my old F150. It still cranked and started well in about 20F weather on its last start.
That's a funny bumper sticker.
   / It finally happened - how long did yours last??? #16
I have never used a trickle charger. With the boat batteries, I just disconnect them. The riding lawnmower battery is a small car battery and I disconnect it and leave it in the mower. Right now it is under 3' of snow. Inspring I will pull the caps off and check to see if it/they are frozen before I put the charger on.
   / It finally happened - how long did yours last??? #17
Two batteries in 28 years in my JD 750. Yuasa for 12 years and a Die Hard for the next 16. Still going with the Die Hard.
   / It finally happened - how long did yours last??? #18
Got 11+ years on original Mahindra battery, 6+ years on Kawasaki Mule OEM battery and just changed the OEM batteries on the 06 Chevy Diesel Duramax. Did some relocating under the seat and was able to get a regular size battery back in the mule instead of the little OEM motorcycle battery. Never cranked so good!!
Note- Used maintainers on the tractor and Mule!!
   / It finally happened - how long did yours last??? #19
   / It finally happened - how long did yours last??? #20
the most we have a battery on our big tractor to last is 3yrs.an thats a tsc battery.now a nh battery will last 5 or 6yrs.will have to see how long the battery last on the 7040su.
2013 Peterbilt 367 20Yd Ox Bodies Tri-Axle Dump Truck (A56858)
2013 Peterbilt 367...
Electric tri scooter irgc40 (A56859)
Electric tri...
2012 International DuraStar 4300 Flatbed Truck (A55973)
2012 International...
BLANTON 12' DRAG HARROW (A52708)
BLANTON 12' DRAG...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2019 INTERNATIONAL...
2019 John Deer 3038E 4 x 4 Tractor w/300 E Loader, S/N 1LV3038EJKK126097, Diesel Engine, Joystick (A59076)
2019 John Deer...
