Front end loader control is stuck.
/ Front end loader control is stuck. #41
How does the vinyl guard come off? Tried to remove it and don't know how it fastened.
/ Front end loader control is stuck. #42
Page 11 in B7800 loader parts document shows the cover as part 290, looks like bolt 300 is what holds it on.
/ Front end loader control is stuck. #43
Thanks for your help. I will give 300 a try.
Do you have the same control valve on the 2710?
/ Front end loader control is stuck. #44
Yes, I had the same problem when mine was under warranty and the dealer came and fixed it in my garage. I wasn't home to watch, I assume they cleaned up the spring and balls and drilled a drain hole.
/ Front end loader control is stuck. #45
I have a question about the parts diagram.
Parts are assigned either a number or a letter on the diagrams.
Where do I find reference to the parts that have a LETTER designation?
/ Front end loader control is stuck. #46
Lettered parts are only available as part of an assembly, the assembly has a number. So for example on page 9 at the lower right on the page, the assembly #020 includes all the parts labeled A-J. So that means you can't buy part A by itself, you have to buy part #020, which includes the whole kitchen sink.
/ Front end loader control is stuck. #47
Thanks, that makes sense. Appreciate the help.
/ Front end loader control is stuck. #48
I have to remove the loader on my tractor.
Can I remove the cans on the loader control valve to clean and lubricate while the loader is off and the hydraulic lines are detached?
Do the parts (that I see in the diagram) come off the valve when I remove the cans? If so, how difficult is it to reinstall the inner parts
when the cans go back on?
Anything I should know regarding the removal and installation?
Looks like the cans are 1.25 in. SAE. I assumed Kubota tractors would require Metric tools??
/ Front end loader control is stuck. #49
You could make a video of the dissasembly.
Use the PDF to put things back together correctly
/ Front end loader control is stuck. #50
JJ-Can the cans be removed and cleaned with the loader off and hoses detached?
/ Front end loader control is stuck. #51
You might check for youtube videos that will help you, I found this one. Go to minute 4, the guy is taking the detent balls and springs out of his valve. There's probably better ones if you hunt around.
I also video things like this when I take them apart, then dump the video on my laptop so I can watch it while I do the reassembly.
/ Front end loader control is stuck. #52
Yes sir, that is correct.
/ Front end loader control is stuck. #53
Be careful, with the HUSCO valve the detent balls are a similar design with 4 balls energised by 1 larger ball with a spring behind it. Where you have to be careful is that when you remove the detent sleeve the balls have a tendency to "spring out". Just be careful you do not lose them. Make sure you lubricate them on reassembly.
/ Front end loader control is stuck. #54
It's been too cold to do this repair. If I were to carefully drill weep holes towards the bottom of the sleeves (while still assembled), will that damage anything?
Seems as if that might be easier than removing them??
/ Front end loader control is stuck. #55
I can not comment or condone this type of modification, however, I understand the problem. I am not exactly sure the internal configuration but if you take a look at the part number on the nametag I will be able to have a look.
/ Front end loader control is stuck. #56
You need to inspect the assembly anyway, so look for a weep hole or drill one when you have it dissembled.
2014 Gradall XL3100IV 4WD Rough Terrain Wheeled Excavator (A61567)
2014 Gradall...
New/Unused Landhonor Mini Skid Steer Pallet Forks (A61166)
New/Unused...
2007 CAT Model C500 Forklift (A61567)
2007 CAT Model...
2025 Swict 78in. Bucket Skid Steer Attachment (A61567)
2025 Swict 78in...
Railroad Maintenance Machine (A61570)
Railroad...
New/Unused Landhonor 78in Quick Attach Rock Bucket (A61166)
New/Unused...
