Axle replacement options
/ Axle replacement options #1
MillWeld
Gold Member
Durham NC
Ford 641
My portable sawmill has a 3500 lb axle (2.375 inch dia) with brakes and 13 tires. Trouble is, the axle is bent on one side (see pic) presumably due to bouncing over roads over the last 12 years. I need advice on replacing it. Obviously a heavier one is needed or the present one straightened and beefed up. I prefer to go with a heavier one but a 5200 lb one will have a different brake mounting flange requiring new brake assemblies and therefore new wheels and tires also a very expensive modification. I would like to get a 2.375 inch axle but with a thicker wall, say シ? and with the same brake mounting flange and spindles so I don稚 have to replace anything else. I can weld and could put it together myself but I need a source for parts. I immediately thought of the expertise of TBN members for advice. Any suggestions?
Bob
/ Axle replacement options #2
First question how often do you move it and from where/distance?
If short trips once or twice a year maybe not worry much and replace tires as needed with free junkers.
If half dozen time a year then maybe fix it by using heavy jack and chaining bent end down under a heavy beam & chain. might need a bit of heat but could reinforce axle with some angle iron after it is straightened. notch it for the leave spring U bolts and by tacking it to the axle it reinforces it all.
3rd buy a all new replacement for couple hundred bucks from REDNECK or one of many places for trailer parts.
Mark
/ Axle replacement options #3
on my sons trailer we built an axel bender, and saved a lot of tires, over the years, (the trailer came from the factory with a bent axel they dropped in building it,
we had a old plow iron about 1"x3" inches and made a few loops of flat stock and the iron was filled with holes so we use a stubby 20 ton jack and have straighten a few axels,
pictures are of fords axel benders that is where we got the idea is from some old ford truck manuals,
on yours one could take it off and find a metal working shop and have it pressed back in a press,
then I would truss it a little,
a rod and a few blocks near the U bolts, or a piece of flat with the U bolts area notched out and just run it across the bottom of it a 3/8" by 2 1/2" flat welded under the axle.
/ Axle replacement options #4
I was pricing axles and parts a couple years ago. I determined that a total replacement with heavier was cheapest route. Got the axle, brakes, rims/tires, springs and hangers all for less than $500. Beefed up that old home made trailer so it was a 5000# trailer. I bought it a a local cargo trailer dealer that had parts and their own shop. I did my own work on this one.
Ron
/ Axle replacement options #5
Your sawmill probably weighs less then the rating of your current axle the problem is in the spring mounting points. They are supposed to be much closer to the hubs. BUT!!! It would prevent the proper access to the mill while sawing lumber and would be awful tippy to tow. I would go with a heavier axle or straighten and reinforce the current one.
/ Axle replacement options #6
Just weld two plates with matching 4-bolt pattern to some pipe of the appropriate length and diameter.
Dave
/ Axle replacement options #7
I'd just take the time to straighten it, then add some reinforcement to both sides of the axle (If it bent on one side, it could bend on the other side later on)
I would like to straighten and reinforce it as most of the replies indicate but the reinforcing part presents the issure of reducing the ground clearance. I have only 12" now and welding a notched plate on the underside will reduce clearance by the width of the plate. I guess I could plug weld a plate on one (or both) sides of the tube but that would not be a continuous weld.
I like making my own like byronlj said but welding the spindles exactly parallel to the tube is one-chance-to-get-it-right effort. Any tips on this?
SPIKER, I don't move the mill much but I hate not having my sawmill not in top shape - especially the towing due to potential danger.
easygo, you're right, the load is too much overhung but it has to be for safe towing.
/ Axle replacement options #9
Is there any way to weld brace on top of the axle by / behind the hub , then have the other end of brace angle up towards the actual frame of mill ?? ( directly above center of spring , can't see in your picture what is there due to cross member ) . Axle bent up , so rather than brace from below and lose clearance , I would try to get something on top after straightening it . As mentioned , with so much space between spring and hub , lots of leverage there , so if possible , come off top of axle back to frame .
Straightening it should be no problem , a pain but not a problem , Just depends on what tools and materials you have available .
Fred H.
/ Axle replacement options #10
If you were to build another axle, why not slip a larger diameter pipe over the new one in the two weak points for reinforcement.
Dave
From all the suggestions I have received, I plan to do:
1. cut the axle about 8" from the brake mounting flange
2. slip/press a larger 16" tube/sleeve over the cut end leaving enough room for a torque wrench to fit over the brake plate nuts and weld
3. slip/press a pipe (~2" sched 80) in the other ends of the sleeve and weld.
The 3" sleeve will rest on the springs so I will change the u-bolts to acommodate them.
I need to locate the steel and the sleeve will need some machining. I'll post pics when the parts are ready to assemble.
Thanks for replies,
Bob
/ Axle replacement options #12
The answer is simple - Rotate the axle 180 degrees and continue drive over the same roads for another 12 years... that should put it about straight, THEN weld up some reinforcement to keep it from bending further! (kidding of course) ;]
It's even simpler - I will just drive backwards over the same routes of the last 12 years.:D Reverse things and you reverse the effect, right?:confused2:
Bob
I pretty much followed my plan in post #11. Today I got the pipe back from the machine shop where they bored out the OD to receive the old axle (cut off to 6" long). I drilled suitably places holes for plug welding, inserted the axle/spindle assembly into the sch 80 pipe, plug welded and welded around the end of the pipe. Then I placed, leveled and welded the spring seats. Electrodes were E6011 and 7018 both 5/32". Went pretty fast. See pics.
I made pretty careful measurements to assure my torque wrench would still fit over the brake mounting flange nut with the larger diameter pipe.
Tomorrow I fish the brake wires thru the axle, put the brakes and drums on and hang the axle under the sawmill and mount the wheels. :cool2:
Yes. I bought new Ubolts. New axle is on the mill now. Pics to follow when I get the brakes connected.
Bob
/ Axle replacement options #18
Bob
I was just wondering if they were available for the new tube size, but apparently you knew they were before setting the saw in the axle :)
The axle is installed. The Ubolts are for a 3" axle and the sch 80 pipe I used is 2.9" so I inserted a u shaped shim around the Ubolt to take up the gap. Don't know if that was necessary but it was easy to do. Also the threads on the Ubolt were not long enough so I added a 1/2" bar on top of the plate. See pic. Its torqued down to ~60 ft-lbs and ready for wheels to go back on. All-in-all it was a pretty straightforward project.
/ Axle replacement options #20
I missed your original post and as I read I agree with easygo (post 5) as to what caused the bending. It seems you did a great job beefing up your axle at the most reasonable cost. That's what I would have done. Great job.
2008 GMC C7500 WATER TRUCK (A67714)
2008 GMC C7500...
2010 INTERNATIONAL (INOPERABLE) DURASTAR 4300 (A67714)
2010 INTERNATIONAL...
FARMTRAC 555 TRACTOR (A65057)
FARMTRAC 555...
217982 (A65054)
217982 (A65054)
2015 Grasshopper 725D 72in Zero Turn Commercial Mower (A68183)
2015 Grasshopper...
2017 Eager Beaver 20XPT 27ft 24 Ton T/A Tag Trailer (A66736)
2017 Eager Beaver...
