Pallets in fields
   / Pallets in fields #1,051
NO WAY, it's dark out there, very dark.
I'll probably delete the next paragraph in a few minutes because just writing about it gives me the shivers.
You did have a bag over your head to assure a "blind" test, right? That's the idea -- it's supposed to be dark! Rookies.:mur:
BTW, I saw the part you deleted. Maybe we should chug on over to mamby pamby land where maybe we can find some self confidence for you, you jack wagon!
Gunny
   / Pallets in fields #1,052
Wow, you guys up North must be snowed in and the only thing keeping you sane is the pallet thread.
Day 2 no change, however the dog is barking out in pallet field as I type.
Your efforts are deeply appreciated.
To advance your investigations, please equip Whipper with an infrared dog cam and infra-sound recorder. Since no one has reported seeing or hearing truly sentient life forms (discounting the possibility of the Paladin wannabe) in proximity to the pallets, we must examine the light spectra which are not visible to the human eye and the sound frequencies not detected by the human ear. We must extend our five senses to the utmost.
I include a helpful graphic to aid your sensory memory:
https://www.google.com/url?sa=i&rct...paONR3UkcH5RiEzanHZIY_Ew&ust=1391230233187599
   / Pallets in fields #1,053
You did have a bag over your head to assure a "blind" test, right? That's the idea -- it's supposed to be dark! Rookies.:mur: BTW, I saw the part you deleted. Maybe we should chug on over to mamby pamby land where maybe we can find some self confidence for you, you jack wagon! Steve
That, my friend, is no way to treat a fellow member of the scientific community... What are you trying to hide by deriding fellow investigators? The plot thickens...
   / Pallets in fields #1,054
That wasn't me that posted that -- it was Gunny.;) He practices "tough love."
Steve
   / Pallets in fields #1,056
OPPS I forgot about the bag, my bad. How can I forget the thing in the deleted paragraph. What would do something like that? We need to call it the terror protection bag so others are warned!
   / Pallets in fields #1,057
Gentlemen (and any Ladies in this astute discussion), I've had somewhat of an epiphany!
True, the pallet placement and the ancillary proposals as to their purpose have focused our quest, but have we 'had the blinkers on'. Have we not been 'seeing the forest for the trees'?
What if it's not the pallets, per se, but the materials inherent! What if the major factor is the nails used to construct the artifact?
I propose this from personal experience whilst constructing a hay-ring from 6 pallets. During the process I had to de-construct (pull apart with a crow-bar) the pallets that I was going to utilise in order to re-construct them in the desired configuration. In doing so, I discovered an inordinate number of nails had been employed by the 'manufacturer' (and, at times, repair-person) to hold the pallets together. Many were in an 'L' shape, too!
So, are the number of nails a significant factor in our calculations. Is the periodic composition of the nails, and their configuration/placement the underlying answer to our quandary? How important are the 'L' shaped (I'll call them "bent") nails?
I humbly submit this for Peer Review.
   / Pallets in fields #1,058
Wagtail, yes back in post #229 I suggested that we look at the materials, construction, and geometry of said pallets. To date, I don't believe we have even established the pallets are constructed of wood. Likely they are... but we all know what can happen when we assume things as a given.
Odd Couple - "My Strife in Court" (Assume Scene) - YouTube
   / Pallets in fields #1,059
The Texas pallets have fallen - like the Alamo. Is this a normal progression or a failed experiment? We did have 40mph winds but I can't assume anything.
   / Pallets in fields #1,060
Did they fall like dominoes or fold into themselves as in a 'stacking' position?
Pickup Truck (A59230)
2010 Mini Cooper Hatchback (A56859)
2010 Mini Cooper...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE MID ROOF (A59575)
2020 FREIGHTLINER...
Xtreme Power MIG 195 (A57454)
Xtreme Power MIG...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
2012 Ford Expedition 4x4 SUV (A56859)
2012 Ford...
