2010 BRANSON 4720i
/ 2010 BRANSON 4720i #1
rasorbackq
Springfield Nova Scotia Canada
Branson 4720
Having a few issues with my R4 tires with chains installed hitting and rubbing on the 3 point lift arms. Didn't see where the rear wheels can be spaced further apart in the manual. Thought i would ask here before calling the dealer . Might be faster here to get an answer.
/ 2010 BRANSON 4720i #2
Are you using the 3PH or are the arms just flopping around loose. Ether way isn't there some stops on the arms that can be adjusted to limit the side sway?
I do not know if or how the rear wheel width is adjusted on that model.
Contacted the deal and he told me how to adjust the wheels to a further open position so the locked lift arms are not damage. Thanks.
/ 2010 BRANSON 4720i #4
So what's the "secret" re: wheel adjustment?
Please share!
Lunk
Tractor like many others has an adjustable rim. There is 8 different sets ups for different widths. Not really 8 but 4. The first 4 with rim dished in will not fit on the tractor . I just have to decide which width will work best me. as I have an offsetable tiller and want to buy a blower . So I want the tires inside the blower sides.
