YABB; A ballast box that actually started life as a (tool) box finally finished
   / YABB; A ballast box that actually started life as a (tool) box finally finished #1
disney
Gold Member
orlando fl
scag turf tiger 61" #2, gx95, sold f525 twice, f725 sold
Hello all. Although the majority of the box was completed last spring, I just got around to finishing the last part of it (the shovel/sledge/axe/etc. holder). I have room in the box for my 25" sthil 390 chain saw, so there is no need for a separate scabbard. I have a magnetic led dome light (not pictured) for the lid of the box to find things at night. Some of you may remember/ recognize this from my original post titled "ballast box pre pour-am I missing anything?" Given the color; I am tempted to paint those diagonal black strips you see some highway construction trucks, or just paint a really big smiley face on it. I do not remember the (calculated) weight but I believe it is north of 1400lbs (empty).
   / YABB; A ballast box that actually started life as a (tool) box finally finished #2
NICE......
   / YABB; A ballast box that actually started life as a (tool) box finally finished #3
Man, that is nice.
   / YABB; A ballast box that actually started life as a (tool) box finally finished #4
That's slick!
   / YABB; A ballast box that actually started life as a (tool) box finally finished #5
Greenlee...................you must have nothing but money, greenlee is really proud of there tools hence the name green like money!:laughing:
Nah, just a $100, and a lucky find on C/l.
   / YABB; A ballast box that actually started life as a (tool) box finally finished #7
   / YABB; A ballast box that actually started life as a (tool) box finally finished #8
Thanks for the PM to this link Disney. First class box! I have needed one for a couple years but am just now getting around to building one. I also went with a job site tool box with mine welded on a donor 3PH fork from a friend. I decided to just build the weight box with additional internal storage and no tool hangers, as I have already outfitted my tractor with storage tubes for everything else I need to store/carry.
Mine is still a work in progress and hope to complete in a couple weeks, weather permitting. I am going to initially load mine up with dry bags of concrete and test for max FEL usage vs. empty FEL tractor handling. Starting test weight will be ~ 1000#. My 710# ROBB is not near enough weight.
- What is the eye bolt(s) in the concrete used for, tie down?
- What tractor is this used behind where 1400#+ is the proper weight? I may need to purchase more bags of concrete for testing before they are mixed for final.
- How is the receiver tube used with no apparent way to pin on a ball mount?
- Any internal bracing for the 2" receiver tube? I have a 36" long tube that will extend out the back of the box and be welded to the bottom horizontal brace of the fork frame. And planning on welding a couple pieces of angle perpendicular on the tube to add more resistance/support in the concrete, along with some vertical support at the front of the tube inside the box. Comments?
- What is the eye bolt(s) in the concrete used for, tie down? ***yes***
- What tractor is this used behind where 1400#+ is the proper weight? ***deere 110 tlb; I am really light in the rear when at max lift (even when just above the ground), so I really need to add more.*** I may need to purchase more bags of concrete for testing before they are mixed for final. ***cant answer that, but I am learning/thinking that you can only go too heavy if the front gets light, when bucket empty (or changing from bucket to forks)***
***look at the rear corner near the bottom, I have a pin welded to a long handle***
This link may help with the tube question. I didnt want it to hang out the 6+/- inches to get to the pin, as my shin would always be finding it.
Ballast box pre-pour, am I missing anything?
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
2000 ADDCO DH1000 Message board (A49461)
2000 ADDCO DH1000...
2005 International Pier Drilling Truck (A49461)
2005 International...
2003 MACK RD6885S T/A DUMP TRUCK (A51406)
2003 MACK RD6885S...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A51039)
John Deere 5090E...
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
