4wd indicator light?
/ 4wd indicator light? #1
countrybumpkin
Elite Member
Kioti, kubota
Have a L3410 and was curios if anyone knows if there may be a location to install a switch on the transmission for a light when 4wd engaged ?
/ 4wd indicator light? #2
Just wondering if is any cons to have the 4wd engaged all the time, other the fuel consumtion and wearing. To be honest I keep mine all the time on, just when I remembered I switch in off position.
/ 4wd indicator light? #3
You need to take it out of 4wd on hard surfaces. I like my 4wd light that reminds me.
No your correct, a bit of fuel and a bit of wear on stuff but no real harm. As stated above don't Run on hard surfaces , I too would like the light as a reminder, I go from soft to hard surfaces a lot around my place and the lever is down near the platform and hard to see if it's engaged or out by looking.
/ 4wd indicator light? #5
I doubt there's allowances for installing a 4x4 indicator on your machine. There wasn't one for my 5740 so I fabricated one for it.
/ 4wd indicator light? #6
Love the light....where did you mount the sensor and what type of switch is it....???
/ 4wd indicator light? #7
I was going to offer up a suggestion but after seeing this one, that's what I would want on my tractor if it didn't have one.
/ 4wd indicator light? #8
I used a switch like this. This one is on my BX but it's the same as I used on our 5740. It's mounted under the cab by the 4x4 lever.
/ 4wd indicator light? #9
Oh crap, 4shorts... I need one of these too, why are all you BX mods killer? And this could be considered a life/death need. When I put my BX to bed I want to take it out of 4WD but twice I have forgotten to engage before heading down the hill the next time out and now I swear to leave it in always. :shocked: A simple light will not alert me. It needs to be a big lighted sign that I cannot help but to see. Otherwise... it is full time 4WD for me! Actually I could use a seat 'shocker' that buzzes me if I am not in 4WD at a given inclination.
/ 4wd indicator light? #11
Nice mod, I'm going to add that to my to do list.
/ 4wd indicator light? #12
I found a photo of how I hooked up the switch to the 4X4 linkage below the floor just in case someone was interested.
Thanks 4Shorts, I really didn't think there would be a prevision but though it was worth asking, the way you did your switch is what I figured I would do if I had to make something. Not sure what I'm going to do for a light just yet.
/ 4wd indicator light? #14
Your more than welcome. For an indicator light I got an old 4X4 display out of an old Dodge Power wagon. I took the face off the display and mounted to a LED clearance light that you can practically buy anywhere. Worked out great. :thumbsup:
/ 4wd indicator light? #15
I like this! The thing I am not sure of is where to find the switch? Want to give a clue? Just an indicator lamp when in 4WD would be a great start.
/ 4wd indicator light? #17
Varmint you wouldn't make a good private detective :laughing:
If you Googled the part number on it you'd find it for sure. It's actually a fork lift back up alarm switch but I use them for other things such as this. I bought this one at my local truck center. :thumbsup:
It's made by trucklite 92925
/ 4wd indicator light? #18
Paul, you are correct. I looked more carefully, and sure enough, there was the info for all to see. I took the easy path?
Between you and Keith Fenner's Youtube stuff, I have no need for a tee vee for good entertainment.
Thanks.
/ 4wd indicator light? #19
Thanks.
Oh my friend your more than welcome. Just for your own safety the bumper sticker I go by reads "Don't follow me, I'm lost" so be careful watching to much of what I do :laughing:
If you go to the 13:00 minute mark of my video you'll get to see how the 4X4 indicator light works :thumbsup:
/ 4wd indicator light? #20
You should be able to tell if is in 4wd by the way it steers when moving
2021 Kubota SVL75-2 Track Loader (A63118)
2021 Kubota...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61567)
2006 Generac...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2025 80in. Hydraulic Dual Cylinder Root Grapple Skid Steer Attachment (A61567)
2025 80in...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2013 International WorkStar 7400 4x4 Altec AM55E 56ft. Bucket Truck (A61568)
2013 International...
