Tractor News Solution for Bobcat, and Kioti filter removals.
   / Solution for Bobcat, and Kioti filter removals.
How did you do in removing your filters?
   / Solution for Bobcat, and Kioti filter removals. #12
Mine popped right off. Had no issue replacing the engine oil and hydraulic filters at all.
   / Solution for Bobcat, and Kioti filter removals. #13
I had to use a big old pipe wrench on my oil filter. Strap wrench failed, neighbors chain wrench just deformed the can, so dug out my huge 12 inch jaw pipe wrench, and carefully applied the needed pull. It gave in just as the can started to crush - what a relief :shocked::thumbsup::)
   / Solution for Bobcat, and Kioti filter removals. #14
I am guessing this was your first filter change out of the factory filter.. It is pretty easy to get off when you were the one that put the last filter on.. NO problem at all on the second filter change:thumbsup:
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
Truck Metal Cargo Storage Box (A55787)
Truck Metal Cargo...
2018 John Deere 4066R (A53314)
2018 John Deere...
2004 Sterling Acterra Cab and Chassis S/A Truck (A54814)
2004 Sterling...
