TURNPIKE TRAILOR TIRES
/ TURNPIKE TRAILOR TIRES #1
JCSNET
Newnan Ga
Ford 555D
Wife needs new tires on horse trailer. Old tires have dry rot and are no longer safe. The brand that is sold in Newnan Ga is Turnpike for around 390 for 4. The size is ST225/75/R15.. Does anyone have any history or experence with this tire?. Would this be a safe tire in a 10 ply for a 2 horse trailer?. THanks Cliff
/ TURNPIKE TRAILOR TIRES #2
Never heard of them. Price is right though. If it were me I would hunt out Greenballs. Best trailer tire on the market.
Chris
/ TURNPIKE TRAILOR TIRES #3
Chris
I have to agree, I would not put cheap tires on anything that may cost a life if they blow out. CJ
/ TURNPIKE TRAILOR TIRES #5
Chris
Seems to me if the tire meets the specs it's as good as any other tire. Seems Greenball tires are like most other trailer tires... Imported...Chinese....
/ TURNPIKE TRAILOR TIRES #6
I'd stick with an American-made tire (if you can find them). In the past I've had issues with Korean-made tires;I'm sure Chinese stuff is much worse.
/ TURNPIKE TRAILOR TIRES #7
Greenballs are Taiwan made. I agree most are imports but I bet I buy a dozen sets of trailer tires per year. The Greenballs are by far the best. The American made Carlisle and Marathon tires are by far the worst.
Chris
/ TURNPIKE TRAILOR TIRES #9
Take a look at the date. This thread is from 6 years ago. I can tell you 6 years ago I loved the Goodyear Marathon tires. Today they are junk. I like Goodyears overall. Just put a set on my truck in November. So I am not a hater.
Things change year to year. For the last 3 or so the Greenballs are hands down the best. We have them on nearly 50 trailers and not a single failure that was not caused by a outside force such as a nail.
Chris
/ TURNPIKE TRAILOR TIRES #11
Taiwan ,china, Korean, etc, are there any really difference tire in quality ?? I know some will say yes ,but I imagine there are some specs all tires must meet to be sold for hwy use. Other than short tread life on some of the car/truck tires, never had a tire failure. For trailer tires For me it's a toss up. I've got the cheapest 235x85x16"s I could buy on my dump trailer and haven had a tire failure yet and that's hauling 6-7 tons a load. I usually end up replacing trailer tires long B-4 the tread is gone due to dry rot
/ TURNPIKE TRAILOR TIRES #12
Chris,
Are there still different versions of the Greenball, or is that info out of date as well?
There are. I only use the Tow Master Radials. I will not touch a bias anything.
Chris
/ TURNPIKE TRAILOR TIRES #13
I agree about replacing well before they Wear Out. A dump trailer for most is easy on tires due to short distances towed. Campers and boat trailers are usually the worst. People want to get there so they drive fast and it's usually a hour or more at a time. Heat is the enemy. Speed and inflation create it.
Chris
/ TURNPIKE TRAILOR TIRES #14
This thread could probably also use some comments on using the proper valve and rim if you get higher rated tires. If I remember correctly other threads pointed out that the E range tires (which I got) needed an air pressure which exceeded many of the lowly rubber valves.
/ TURNPIKE TRAILOR TIRES #15
That's correct. I use bolt in HP metal valve stems
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
2020 FREIGHTLINER 114SD CAB & CHASIS (A59910)
2020 FREIGHTLINER...
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
Informational Lot - Shipping (A63118)
Informational Lot...
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A59911)
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
