Looking4new
Super Star Member
- Joined
- Apr 8, 2012
- Messages
- 10,620
- Location
- Northern Ontario, Canada
- Tractor
- 2012 Kioti CK27HST w/cab
It was a great story. He is lucky to still be alive to tell it.
Glow plugs are usually (always?) installed in the intake manifold outside the cylinder. If that is where you want the combustion to take place then go ahead and spray ether into the intake...
Nah, ether gets used more and more on engines that have issues to start with. (no pun intended)ether is the equal to heroine to a engine, it will over time make the engine depends on it to start. Someone I know had a JD skidder which in the end had to have a half a can of ether to start even in mid summer
If you will look at your BX2230 you will find the glow plugs(parts key #140 in parts catalog PN 16851-65512) screwed into the cyl head not the intake manifold. All engines that I've seen with glow plugs have them in cyl head. Thermo-start heating elements are in the intake which are different from GP's
To all who post that "a little ether" is ok, sorry, you are wrong. Any use of ether in these engines is destructive. It doesn't matter if it is introduced when the glow plug is on or off. The explosive nature of this volatile compound produces combustion pressures beyond what the engine was designed to contain. Probably a cracked piston head is the most likely result but broken rings, cylinder or head/valve damage is quite possible.
The "squirt a little ether" into a modern small displacement diesel engine advice is the same as "pour a little gasoline on the woodpile" fire starting advice.
Full battery charge, healthy glow plugs, clean air filter, properly treated fuel for cold weather and a block heater for extreme cold will start a diesel engine with proper compression, every time. If yours won't start, check the above and correct, including a compression check.
So, did anyone else notice in his story that he shovelled a path wide enough for the tractor on the way to the barn?
Now that's a story.
I totally agree. I've seen too many engines ruined from misuse of ether.
