handirifle
Well a few weeks ago, I was using my little MF1010 for some light work. I haven't used it in a couple months for anything, prior. So as it runs low on fuel I added some and within minutes it starts running like crap. So I figured bad or contaminated fuel.
When I got done, I parked it till I had some time to work on the fuel. I got on it the other day, and pulled the filter, actually had rust on it. There was a lot of crap in the bowl as well. I have changed the fuel filter, about 90hrs ago, so this was surprising. I got another filter today, but the kicker was yesterday, I cleaned the filter (temporary till I got the new one today) and bled the air out of the bowl. But when I went to start it, the key broke off in the ignition
Well, I have needed to work on the charging system for a bit, now I have the ign switch in the lock shop for a new key. In the meantime I decided to pull the dash to get access to fix the other issues, but now I cannot get the steering wheel off.
This is a pic of as far as I have gotten. I have a puller but it doesn't fit. I am wondering if it indeed needs a puller? If not then how does it come off?
If it does need one, what do they look like?
Suggestions?
Thanks
Suggestions?
Thanks
