From bad to worse
/ From bad to worse #1
handirifle
Central Coast of CA
Massey Ferguson 1010
Well a few weeks ago, I was using my little MF1010 for some light work. I haven't used it in a couple months for anything, prior. So as it runs low on fuel I added some and within minutes it starts running like crap. So I figured bad or contaminated fuel.
When I got done, I parked it till I had some time to work on the fuel. I got on it the other day, and pulled the filter, actually had rust on it. There was a lot of crap in the bowl as well. I have changed the fuel filter, about 90hrs ago, so this was surprising. I got another filter today, but the kicker was yesterday, I cleaned the filter (temporary till I got the new one today) and bled the air out of the bowl. But when I went to start it, the key broke off in the ignition :eek:.
Well, I have needed to work on the charging system for a bit, now I have the ign switch in the lock shop for a new key. In the meantime I decided to pull the dash to get access to fix the other issues, but now I cannot get the steering wheel off.
This is a pic of as far as I have gotten. I have a puller but it doesn't fit. I am wondering if it indeed needs a puller? If not then how does it come off?
If it does need one, what do they look like?
Suggestions?
Thanks
/ From bad to worse #2
I believe it does need a puller to come off. It is a tapered shaft if I recall correctly. I had the key on my Massey get twisted, took it to a lock smith and got a new one made. A key for a 8n ford is the same key.
/ From bad to worse
This darn key didn't even warn me, in fact I was surprised to see it was broken. So now I wait.
/ From bad to worse #4
You're going to need more than just a puller- that column shaft looks like it's been there since forever.
Start soaking it now with some heavy duty rust penetrant and keep it from exposure to the elements. Many AutoZone and other chain auto places may actually lend out certain tools or rent them depending on franchise, etc. Take a better pic with dimensions of the hub by the shaft to a local store and get a steering wheel puller. I'd be concerned about the contents at the bottom of your fuel tank more than your dash issues. There must be rust/water in there and rust on the filter is not a good sign either. Is it gas or diesel tractor? Either way, you want to find and eliminate the water/rust source now.
/ From bad to worse #5
You will need a tool something like this.
ww.toolpan.cowm/ATD-Tools-3040--Steering-Wheel-Puller-Set_p_2083.html?gdftrk=gdfV27228_a_7c824_a_7c2023_a_7cATD3040
There should be two or three holes in the wheel. The little indent in the column is for the puller to push off of. Set up the center, then thread in the bolts as far as you can and then tighten up the center. It looks like it will be stubborn.
/ From bad to worse #6
I agree with the others, looks like might be a problem.
In this COLD weather however you may be able to use one of the PC Cleaner Cans to FREEZE it really cold to try and shrink it some then spray some penetrating oil that is warm onto it. Those cans of Compressed CO2 type (some of the OLD propane tanks) can also output liquid gas to freeze stuff but are more dangerous from fire side of it. (cold causes stuff to shrink and heat to expand.) The Wheel needs to EXPAND and the SHAFT to shrink.
On one particular fitment issues I ended up using both to break a tapered shaft loose. I had already pulled and stretched the wheel puller on that particular shaft & pulley.
HEAT the wheel on the outside Heat Gun or torch & spray w penetrating oil then hit the shaft with the cool stuff.
(NOTE: a great penetrating oil is about 50% ATF and Lacquer Thinner or Xylonole... )
mark
/ From bad to worse
Great ideas, and I agree on some fuel issues that NEED to be cleared up. Getting the dash off is necessary to remove and clean the tank so one step at a time. It's a diesel.
On a good note, I couldn't find a new switch, but a local lock smith has repaired my switch and made some new keys. I will pick those up today. I didn't see any holes for the standard type puller but will look it over again to make sure.
I have been soaking the thing regular, and unfortunately there has been ZERO weather to keep it out of. I say unfortunately cause it's out 4th season in drought conditions. Less than 2" rain here this year, and normal is about 18". A few years back we had back to back seasons with 33 and 40". All the ponds, some several acres, are dried up. Those are my neighbors, mine is tiny. Folks are having water trucked in, but we are fortunate in that our well hit a nice vein of underground water. The well is 400ft deep, but hit the water at 360, and static level came to 60'. That was at the end of a previous 3 year drought, and then we had those two heavy seasons I mentioned. So far so good on the water.
I will keep ya posted on the wheel removal, and the maintenance following. The guy I bought the tractor from didn't do much on it, so it's catching up with it.
Is there a good way to separate diesel from water in a tank?
/ From bad to worse
OK I looked again, as I suspected, there are no holes for a puller, so I need to try the heat gun and see how that goes. I might have to jury rig up something to get under the wheel and use my puller.
/ From bad to worse #9
Water is heavier than fuel , it will be on bottom. Does your tank have a way of draining water off of it, be in the bottom some where. You may have to drain off of your fuel line. LUTT
/ From bad to worse #10
What I have done in the past to remove a steering wheel, when I didnt have a puller. Simply screw the nut back on the shaft, just flush with the top of the shaft, not all the way tight. I place my knees behind the steering wheel and push up on it as hard as i can, I then take one hand and pull on the top of the steering wheel and wack the nut with a brass or shot filled plastic hammer. Dont use a steel hammer as the shaft material is very soft and a steel hammer can deform the threads. This usually works more times than it doesnt. Penetrateing oil is your friend. I have also taken a hydraulic bottle jack and a piece of chain hooked to the wheel and just jacked the wheels off. Get the jack pumped up tight over the shaft nut and if the wheel doesnt come off right away, just leave the jack and chain in place with pressure on it overnight.
/ From bad to worse
Lutt
I will look and see. Thanks
muddstopper
Thanks for the tip.
I picked up my ign switch, and seems more broke than I thought and the key will not stay in it. It literally falls out. Sooo I will try to source out a new one. I have time now since I have other issues to work on.
/ From bad to worse #12
I have an old puller I inherited from my dad that has 2 different sized split rings which could be placed behind the steering wheel then the arms of the puller would hook on the ring to pull with. You put tension on the ring then tapped the center bolt to pop the steering wheel loose. Again pre-treating it with penetrating fluid would be wise.
/ From bad to worse
Well I tried the heat-n-hammer approach, to the point of almost melting the darn wheel. So I decided to drill holes in it. Next I got some 5/16" bolts washers and nuts. I got a piece of 1/4" flat steel I had laying around. Drilled and tapped a 3/8" hole in the center, and ground the end of a 3/8" bolt to a point, and threaded it into the steel. Next I drilled a 3/8" hole about 1 1/4" from center of threaded hole, one on each side. Then I run the bolts through the plate and steering wheel, and backed them up with washers and nuts, run up tight to the wheel.
I started cranking the threaded bolt into the steering shaft, and got to the point I thought the wheel was going to warp badly or break, and POP off it came. When I got the wheel off I looked underneath, and realized just how close it was to breaking. But it's off!
Then I got down to pulling the dash off. I knew I had to pull it because the tractor has not been charging for some time, and when I pulled the ignition switch, I saw one wire had burned pretty badly, so I wanted to find out why and repair it. After some doing I got the dash off and opened the wiring harness to reveal the burned wire. It was burned all the way to what I believe is the rectifier or regulator. A flat plate with fins on it.
So I pulled the rectifier, and also pulled the generator. At least that's what I think that is. I have never seen one like this. There are definitely magnets in it, cause when I turn it, it feels like engine compression about every 1/8 turn. I am going to have them both checked out. I had the battery checked before so it is good.
Oh yes, one more thing. The top bolt on the generator broke when I tried to remove it. Good grief. Old stuff is fun to work on.
Once the problem there gets corrected, I will try to figure out the fuel problem, which was the reason I started this job in the first place. Oh well, I have been putting off working on the charging system too long anyway. It's a good running tractor, or it was before the fuel problem, and I want it to be reliable too.
Thanks for the pointers guys, much appreciated.
That split ring puller would have done the trick. I tried to figure out how to rig one of those up but couldn't do it with what I had around here.
/ From bad to worse #14
Why not upgrade to an alternator with built in voltage regulator while you have everything apart?
/ From bad to worse
I am fully open to that idea, never even thought of it honestly. Not sure I know how to change the wiring around. I need to locate a wiring diagram anyway. I replaced the burned wire and got the wires re-wrapped, and tomorrow I will have them tested, and check on the alternator idea. Thanks.
/ From bad to worse #16
Yes' just put in a simple GM 10 SI one wire alternator. You will probably need a smaller pulley to get the alternators speed up.
Chris
/ From bad to worse
Chris
But what about the regulator? It has about 5 wires feeding into and out of it? That's where I would get confused. Like I said, I THINK it's a regulator.
/ From bad to worse #18
Post pictures of items in question and wires to & fro.
/ From bad to worse #19
My guess the regulator can go also and just a few wiring modifications will fix it all up.
Chris
/ From bad to worse
OK an update. I took the generator and regulator to the local NAPA, and they sent it off. It came back 2 days later, it was a burned terminal in the connector, that joins the tractors harness. Total cost there, $10!! I drilled out the old broken bolt, and since it would not come out, (don't have easy outs) I tapped it for 1/4-20 and used a bolt I had.
I got my shop manual and with wiring diagram I rewired the ignition switch. The switch isn't quite right, but I can replace it later. I replaced the old gunked up fuel filter, and cleaned the fuel bowl. I bleed the air out of the filter housing. I replaced the regulator to ignition switch wire that was burned bare. I also got a roll of fusible link wire (14ga) since the wire it served was 10ga. After this I replaced the dash, and that took some real doing, but got it. Got the steering wheel back on, charged the battery, and gave it a go. Fired right up and (it seems) it runs better than before, but that's kinda like washing your car, seems to run better as well.
None of my lights work, nor the horn, but now with the manual I should be able to get those going too.
Thanks for all the input and suggestions.
