Battery
/ Battery #1
Looking4new
Super Star Member
Northern Ontario, Canada
2012 Kioti CK27HST w/cab
I have an Interstate 12Volt battery that came with my Kioti (2012). Question is; (A) How long is this battery supposed to last and (B) wouldn't 2 of 6 volt batteries wired in series do a better job?
/ Battery #2
I have a CK30hst and the battery, I believe a group 24, is 10 3/4 inches long and 800CCA. It pretty much fills the entire battery tray. I haven't seen small 6 volt batteries where two would fit in that area and give you that much CCA. If you can find them, then yes, two can be connected together in series.
My first dealer installed battery lasted 5 years. I bought another after that, at an auto store, that has a six year warranty. It's hard to guess how long your battery will last. I had one in another tractor that went 8 years.
/ Battery #3
Just bought my 3rd battery for my Kubota. It is 25 years old and it was the switch that went bad but I thought it time for a new battery.
/ Battery #4
My 2002 Kubota was still starting the tractor nicely when I traded it in 2010. why do you think 2 six volt batteries would be better? Batteries are just 2.1 volt cells wired in series inside of a rubber/plastic case with the end leads brought out of the case.. Why would having 2 cases of 3 cells each make it better? If anything it would be less power in a given unit of space because of the need for additional case walls.
/ Battery
I'm thinking that 2 6's in series would give me more oomph than 1 12V. Maybe my thinking is skewed a bit. maybe 2 12's in parallel would be better.
/ Battery #6
Yes, 2 batteries in parallel would provide more current .
/ Battery #10
There is no telling on how long a battery will last. The closer to a full charge it is kept to the longer it will last. If you are using the tractor every couple of days there should be few problems and the battery could last up to 10 or more years. If you are not using the tractor for an extended period of time it should have a battery maintainer put on it. What kills batteries is the discharge of the battery below a certain level repeatedly, and being kept at that discharged level.
/ Battery #12
More CCA = faster cranking
More reserve capacity = longer cranking.
What you want is higher reserve capacity as well..... high reserve is always good.
Also I'm a full time truck mechanic and there is nothing better with two batterys vs one. John Deere for YEARS had two 6 volt battery connected in series to make 12 volts. Series is not a reliable set up when it comes down to it. There is one path for current, and your relying on the high voltage. The amperage averages out.
If one battery goes bad it brings down the other one as well. Two battery's is not better than one.
Series connection you double the battery voltage but amperage stays the same!
Parallel the voltage averages out but the amperage is added up.
Load test your battery and call it good! Keep connections shiney and coat them in a protecant. And yes clean connections makes a huge difference. Clean connections are more efficient on the battery which is easier on it. Tieing Down a battery makes it last longer as the cells are not "beat" around all over.
A clean battery is more efficient! Keeping the top of your battery clean creates better flow internally.... seriously!
If your machine is having trouble starting its not just a battery problem. You may have dirty connections and it seems to be a battery issue.
Oh and keeping the battery terminals clean prevents the battery cables from internally corroding out.
Any more questions feel free to ask but I hate it when a truck pulls into work with starting troubles and 3 out of 4 batterys are good. That one battery was pulling down the whole starting system! Happens all the time.
Buy the highest reserve capacity battery with good or high CCA rating. And interstate batterys are very tough as well.
/ Battery #13
A little off topic, but can someone explain the chemistry behind not storing batteries on a concrete floor? Or is that a wives tale?
/ Battery
When was the last time you removed the cable clamps from the battery and really cleaned both the clamps and battery terminals?
That would be last fall, just before winter set in. I do that with my Heep and the Kioti.
I am leaning towards two either blue or red top Optima AGM batteries. I do need a newer battery for the Heep and that will be an Optima yellow top. (Winch)
/ Battery
I have heard that it is an old wives tale. Any of my batteries that are good, I keep them on a 2x12 plank, anyway. At the price of good batteries, I am not going to take the chance that it might be true.
/ Battery #19
We have a 2004 CK-30 still has original Interstate battery but keep a maintainer on at all times .
/ Battery #20
Gel batteries (like Optima) and AGM batteries are valve-regulated lead-acid (VRLA) batteries. They are sealed and can be used in any orientation, won't spill acid, and tend to tolerate vibration better. The main advantage of VRLA for us tractor types is their very low (compared to normal "flooded" batteries) self discharge rate; they won't go dead if they sit uncharged for weeks or months (well, they do but very slowly). On the minus side, they are less tolerant of overcharging. With spiral-wrapped gel batteries, like Optima, the cells are cylinders and this limits battery size and shape to an extent (width is 150% of the depth). AGM batteries use rectangular cells so they can be just about any rectangular shape. VRLAs cost about twice as much a flooded batteries but may not last about as long, all things being equal (which is seldom the case). It's easier to kill a flooded battery by undercharging or contamination and easier to kill a VRLA by overcharging. My 2006 DK45S still has the original AGM battery, I think (not sure because I bought it used).
All this notwithstanding, there is no value in putting too much battery in your tractor unless you plan to run the radio for long periods with the engine off. If a healthy battery can't start your Kioti, almost immediately, something in the tractor needs to be fixed. The exception would be a very cold climate. But even there, a block heater and battery heater are a better strategy than a super big battery. The super big battery can cause excess stress and wear of unlubricated surfaces until the oil flows; but the block heater helps the oil flow quickly and the battery heater will yield the full cranking amps. on a related topic, a good synthetic motor oil will flow at much lower temperatures than conventional oil.
John Deere Rear Rim (A64119)
John Deere Rear...
2016 Nissan Titan XD 4x4 Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
Kubota KX080-4 Mini Excavator (A65579)
Kubota KX080-4...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
John Deere 980 30' Field Cultivator (A66285)
John Deere 980 30'...
