Tires I could use some tire advice R3039H owners
   / I could use some tire advice R3039H owners #11
I have no problem at all plowing or blowing snow with turfs. It is used on the yard because that 72" belly mower works great. I have a 5' tiller I use, no problem. If you are driving over stumps and rocks, the r4's are good because they are tough. Search the net for people cutting sipes in their r4 tires to help on packed snow and ice. snowblower1.jpg
ruffdog,
Those old diamond turfs is exactly what was on my Cub when I bought it. And from your picture I can tell your turfs gotta be magic! Haha! I'm sorry for comparing the two. But don't mow with a tractor anymore. I blaze across my yard at 12mph on my Exmark mower. So turf tires are a no for sure.
Thanks for the reading. The one thing I was worried about with R4 tires, was performance in the snow. Sipping R4 tires for the snow might be the way to go.
   / I could use some tire advice R3039H owners #14
Have a3039 here with the r4's no problem with traction and I'm plowing a hill with mine, my rears are filled with rim guard , i did add chains to the front wheels because of the front skating with the plow on it, not a tire problem just a to far out on the loader problem, OP where in PA are you? how much snow do you get ??
   / I could use some tire advice R3039H owners #15
I plowed for 11 winters with turfs and hesitated to settle for R-4s when trading in, with the dealer saying "that's how they come anymore" explaining the '6-ply' carcass vs '4-ply' of R-1s or R-3s. I plowed 4", 6" and 12"+ snows this year and wouldn't have known the difference between my old and new virtually twin tractors with supposedly the 'best' and 'worst' winter options. Would have siped the R-4s in a minute if it had come to that.
My driveway is 550' long and after our recent tree trimming ice storm, a two day thaw, and temps returning to the teens & 20,s mine and the neighbor's drives (120' plus a large turnaround) are veritable ice rinks that make foot traffic all but impossible without a dusting of crunchy powder on top. The 12'+ snowfall was removed after this condition evolved, more piling than pushing this time but with never a thought to any unrealized 'slippage', or doubt that my rubber was up to the task.
I suspect that reports are often specific to anecdotal and extreme experiences that IMO may lead to over-interpreting the differences of the 3 common types, esp in winter conditions. I'm sure that having only pancake-flat surfaces and using ballast renders my comparison invalid vs others with hills & slopes, tho' 4wd is often needed to maneuver our trucks quite in contrast to the tractor doing so well even in 2wd. M&S road vs turf vs R-3 tires doesn't seem to matter enough to draw any conclusions in these conditions. btw: No clutching on the AT-equipped trucks or HST tractors. Whether that matters much is unclear, but one reason I stopped driving 'sticks' otr was poor winter driving o'all.
What I haven't learned yet is whether tire differences are as obvious as as I had expected in the various seasonal conditions. The R-4s are kind to my soft lawn, tho' it's sandy and well drained. No conclusion. I did have a few drips of RimGuard from a rear fill stem when plowing at 13^ F and wondered if the stuff might have been at the threshold of freezing up. I'll look for further leakage in warmer temps (not there above 15^ F). Still, there will be times when chains are called for and IMO no tire will obviate that necessity.
Traction, lawn damage, etc seem to be mostly subjective, as is appraisal (YMMV), but I no longer believe that choice of rubber can ever matter as much as 2wd vs 4wd use whether with truck or tractor. Either way, I feel well-prepared for winter whenever it arrives & can't imagine I'd be much happier with turfs or R-1s at his point. btw: tractors I pitched in to get 'unstuck' earlier this winter ('04 JD 60+hp, Kubo MX5100 & not using my little NH) were up to their axles in soft ground and got there wearing R-1s all around, so to me it's all 'relative'.
Whether this post is the least bit helpful, or if seasonal tire rotation (summer to 'snows' as of yore) was worth the expense and effort, more of us would be doing so and posting about the cleverness or merit of going back to the old ways. ;)
   / I could use some tire advice R3039H owners #16
Had turf tires on my 4310, had no issues plowing snow. Purchased my new 4120 with R4's and was concerned about traction in snow after reading some comments in this forum. Could be the increased weight but the R4's are as good or possibly better in the snow. Had 17 inches of snow a couple weeks ago here and pulled a 7 ft rear blade with no problem. Driveway is 350 feet long with a 10 deg incline at end.
   / I could use some tire advice R3039H owners #17
off topic but as i read the post here it seems to me, that the type of tire is not as important as having the weight and enuf tractor to do the job needed
   / I could use some tire advice R3039H owners #18
And I might add, a competent operator.
Do all of you have your rear tires loaded?
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
2017 Wanco WSDT3-S S/A Towable Radar-Speed Trailer (A55973)
2017 Wanco WSDT3-S...
Adams 6T Fertilizer Spreader (A56435)
Adams 6T...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A55745)
2015 VANTAGE...
Gradall 53409-45 Telehandler, Turbo Diesel Engine, 45' Reach, Rear Steer, 60" Forks, 6,699 Hours (A59076)
Gradall 53409-45...
2015 Chrysler 200 Sedan (A56859)
2015 Chrysler 200...
