JD 5083 or T4.75
/ JD 5083 or T4.75 #1
Brian C 4676
Kentucky
LOOKING FOR ONE
I am looking to purchase a new tractor this year and I am not sure which way to go. I've read reviews, looked tractors and would love input from actual owners.
I will be mowing, haying, feeding cattle, maybe planting some 15-20 acre fields (dove shoots, hay, etc?. FEL will be necessary as well as future attachments (bucket, grapple, hay spear, etc?
Thanks for any and all comments
/ JD 5083 or T4.75 #2
They dont make the JD 83e anymore. The 85e took its place. My personal opinion, the JD is a lot more tractor. Weights more, lifts more, better hydrulics. If you like NH's look at LS tractors.
/ JD 5083 or T4.75
Thanks for the advice! I don't doubt your comment about the 5083e… but I have seen them around on lots.
What all do you have on your 85 and what do you do with it routinely?
/ JD 5083 or T4.75 #4
Why do you say "if you like NH look at LS"?
/ JD 5083 or T4.75 #5
I think 12 was the last year of the 83e. The 85e has the tier 4 emmissions. They changed a few other things also. I ordered mine in dec. and it should be here first week or two of febuary. I have 120 acre farm and will be doing mostly food plots, maintaining native grasses and eventually farming 40 acres of it. You can check out my thread in the JD forum for all the options I got. Talked to a lot of people with newer 83 and 85m, most everybody I talked was happy with their purchase.
/ JD 5083 or T4.75 #6
From what I understand of LS they make some of the NH tractors. Looks like they are very similar machines. If memory serves me correct there also cheaper.
/ JD 5083 or T4.75 #7
What size mower and hay equipment,will you be using? The NH 4.85 will be closer to the 5083/5085. I run a 5083 for a friend feeding cows,i haven't spent any time on a 4.75 besides the dealer lot,has a nice cab. I do like the changes made on the 5085.
/ JD 5083 or T4.75 #8
While LS and NH have a lot of connections, LS doesn't make the T4.xx series for NH. The Powerstar T4.xx are made in Turkey by Turk Traktor, using a Fiat engine, which makes sense now that Fiat owns CNH. I'm sure it's part of their cooperative agreements, but the very similar LS P-series machines also use the same Fiat engines. It appears that LS actually buys some of their larger machines from CNH, and then sells them outside the U.S.
$50K gets you a LOT of machine in an LS P series...85hp at the PTO, over 6K on the 3pt, and 3,500lbs on the FEL....I swear my dealer posts this to make me drool! New LS 7040CPS tractor loader, 97hp
/ JD 5083 or T4.75 #9
GmanBart explained it well. LS does make the NH compacts but nothing to do with the utility size and bigger.
Brian,
If you want me to email you an extensive review of the 4.75 just PM me and I'll send it to you.
Your looking at two really nice tractors!
/ JD 5083 or T4.75
Mower… 15 ft bat wing - Haying - not sure yet but nothing out of the ordinary. Have about 50 hayable acre, 50 tillable, rest woods.
/ JD 5083 or T4.75 #12
While LS and NH have a lot of connections, LS doesn't make the T4.xx series for NH. The Powerstar T4.xx are made in Turkey by Turk Traktor .[/url]
Not sure where you are getting your information on this, but they are built in Jesi, Italy by CNH.
/ JD 5083 or T4.75 #13
Get whichever tractor makes sense to you, all manufacturers are going to have issues at some point; just make sure you have a good dealer.
/ JD 5083 or T4.75 #16
I own one (T4.105), and I can tell you mine is built by CNH in Jesi, Italy. It says it in multiple places on the tractor.
We were talking about the T4.75....different model. Lots of companies make related models in different factories.
(1) Firestone 480/80R50 Tire (A60462)
(1) Firestone...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
1011 (A61165)
1011 (A61165)
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
Caterpillar Quick Attach Forks (A60463)
Caterpillar Quick...
