Quick Hitches Land Pride Quick Hitch
/ Land Pride Quick Hitch #101
The Speeco has cat 1 hooks and is not the same as a Land Pride QH. Just got back from Rural King and seen the Speeco for 119.95 in person. The Land Pride has Cat 3 hooks.
/ Land Pride Quick Hitch #102
Murph;
Just to add more confusion, the SpeeCo CAT 2 QA has CAT 3 hooks on lower and CAT 2 on upper link. We have the TSC version of this one.
Have not looked at the CAT 1 QA since we have the Delta Hook on the Kubota and it's implements.
/ Land Pride Quick Hitch #103
Murph;
That SpeeCo is junk compared to the Land Pride. No comparison.
/ Land Pride Quick Hitch #105
So you have used, or even seen a SpeeCo CAT 2 QA? Ours works well and fits any CAT 2 QA Compatible implement we have, with no modifications of the implement. It is certainly heavy duty and heavy. Used the Kubota FEL to lift it and install on the New Holland. What is your quick appraisal based on? Trust it is not just because it's not the brand you bought? ;-(
/ Land Pride Quick Hitch #106
I am only talking about what I've seen not what you heard.:) a Cat 1 hitch
/ Land Pride Quick Hitch #107
DeltaHook I thought the Land pride QH20 CAT 2 was expensive @$700. Holy smokes it's more than twice the price and the ones shown are not even clevis style.
I've looked at the speeco and landpride they do not share the same design or at least they didn't. Most of the speeco stuff ive seen is made in China not sure if the QH was or not
/ Land Pride Quick Hitch #108
We have the CAT 2 QA and specifically noted that are not familiar with the CAT 1. Don't know where the "not what you heard" comment comes from? You condemned a complete "brand" with no basis of fact other than possibly "looking" at the SpeeCo CAT 1 QA. Did you actually inspect one or see it on the internet? ;-(
/ Land Pride Quick Hitch #109
I seen the Cat 1 at Rural King. No insults intended just comparing the two QH's
/ Land Pride Quick Hitch #110
OK. The LP QH15 is not absolutely identical to the Speeco E-Hitch that New Holland markets. The latch handles are clearly different. But they are both Cat I hitches that accept Cat II lower implement pins, offer an optional swivel link for implements with flex links built into the toplink mount (standard on the Speeco E-Hitch). Both weigh 70-75 lbs. THe Speeco unit is rated for 50 HP and it is doubtful that anyone would rate the Landpride QH15 much over that.
http://www.landpride.com/ari/attach/lp/public/lit/lit_qh15.pdf
SpeeCo Inc. Farming accessories and tools, log splitters, post hole diggers and custom manufacturing.
Anyone interested can compaer the specs, weights, and whatever else that is published about these units by poking around the manufacturer's websites.
/ Land Pride Quick Hitch #111
I just can't imagine there has been 110 replies to this thread. It's a QA not a tractor or space ship. I paid $85.00 three years ago and never were concerned with Cat1, Cat2, or Cat3, or bushings. It fit. Does the job. Gets greased along with the tractor and other equipment. And it's simply a QA.
/ Land Pride Quick Hitch #112
DeltaHook I thought the Land pride QH20 CAT 2 was expensive @$700. Holy smokes it's more than twice the price and the ones shown are not even clevis style. I've looked at the speeco and landpride they do not share the same design or at least they didn't. Most of the speeco stuff ive seen is made in China not sure if the QH was or not
Xring;
The Delta Hook receiver plates adapt to individual pins or clevis style. The lower link connects slide laterally and have several holes to adjust vertically. They have tons of flexibility. I am surprised other companies have not copied. DH must have strong patents and defend them. It is SO easy to hookup, especially non PTO implements. It's really just seconds, back up, raise your 3 point, and go. We have hydraulic upper link which makes it even faster. The HUL real benefit is when dropping your implement. We park bush hog, box blade, etc. on blocks, on concrete so they are aligned and level to start or end with.
Well worth the $$$ IMHO.
/ Land Pride Quick Hitch #113
OK. The LP QH15 is not absolutely identical to the Speeco E-Hitch that New Holland markets. The latch handles are clearly different. But they are both Cat I hitches that accept Cat II lower implement pins, offer an optional swivel link for implements with flex links built into the toplink mount (standard on the Speeco E-Hitch). Both weigh 70-75 lbs. THe Speeco unit is rated for 50 HP and it is doubtful that anyone would rate the Landpride QH15 much over that. http://www.landpride.com/ari/attach/lp/public/lit/lit_qh15.pdf SpeeCo Inc. Farming accessories and tools, log splitters, post hole diggers and custom manufacturing. Anyone interested can compaer the specs, weights, and whatever else that is published about these units by poking around the manufacturer's websites.
We have the TSC version (copy) of this one. 160 lbs. and as previously noted, installed it with Kubota FEL and lift slings. Goes to say, not interested in routinely removing it for no reason.
http://www.speeco.com/products.aspx?id=209&id2=211&prod=166
/ Land Pride Quick Hitch #114
Speeco Cat I hitches at the local farm supply have Cat III hooks and come with a pair of the Cat I to III big-end adapters.
Bruce
/ Land Pride Quick Hitch #116
If you have a Cat II QH, it's not a copy of either of the Cat I's I mentioned. A true Cat II will be wider and taller than a Cat I. There's more to the difference than lift pin diameter.
/ Land Pride Quick Hitch #117
Very good information Matt. Thanks for posting and clearing the air. I totally agree with LP's logic about pin fit. It appears Murph has the same setup and he confirmed yesterday that his QH definitely has CAT III hooks. I wonder how many other manufacturers of QH's do this?? I'm guessing not many. I think all of the Chinese made CAT I QHs are CAT II hooks.
Good stuff guys, thanks for posting all the info. It'll definitely help others purchasing QHs to decide what they need. :thumbsup:
Not true my HF quick hitch has cat 3 hooks also.
/ Land Pride Quick Hitch #118
Obviously the more we discuss this, the more differences come to light. Now it even appears that companies like Speeco offer different QHs, even though they are the same category.
Our local Farm Supply store stocks Speeco. I checked out the CAT I QH. They are very well built and heavy. Nothing cheap about them at all. They come with a Top Link adapter and roll pin CAT I to CAT II bushings for the lowers. The lowers are CAT II.
So now I'm more confused than ever. AND,,, I still don't know who makes Speeco's QH or LP's for that matter???
I'm beginning to think everyone is importing them. The differences are simple contracted specification requests.
If ordering one, sight unseen, I'd want to know the lower hook size. I'd also want to know the weight of the product. Those two things will give you an idea of the durability that you are buying. Otherwise,,, who knows what you'll get.
/ Land Pride Quick Hitch #119
FYI
My HF quick hitch has a top link hook about 1 1/4 inches and the bottom hooks are about 1 1/2 inches
/ Land Pride Quick Hitch #120
FYI
Yea the only thing I have found on the HF QH that needed attention was the top hook. It needed extended so that it would reach the top pin (bolt, sleeve) so I did this
That isn't mine that is someone else's but mine looked just the same of course I didn't take a picture.
Wheel Loader Root Rake (A68134)
Wheel Loader Root...
2025 Grapple Rake Mini Excavator Attachment (A66734)
2025 Grapple Rake...
2018 GENERAC MOBILE PRODUCTS MAGNUM LIGHT/WATER PLANT (A67714)
2018 GENERAC...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
MQ MULTIQUIP PUMP (CONDITION UNKNOWN) (A68842)
MQ MULTIQUIP PUMP...
Year: 2018 Make: GMC Model: Terrain Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 116,222 Pla... (A66738)
Year: 2018 Make...
