DJ54
Elite Member
- Joined
- Jan 20, 2009
- Messages
- 4,669
- Location
- Carroll, Ohio
- Tractor
- IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
I've got a couple of the hand held/wall mounted similar to the HF cleaners. Even have a couple A-C old timers like picture below, with different inserts for different sized plugs. Like Soundguy, I have 7 tractors that use the same plug. Usually have 3-4 sets in the tune-up cabinet, cleaned, re-set & ready to install.
As for the Black Beauty. If you look it up, they call it coal slag. What it actually is, is screened & washed coal cinders. The material left over from coal burning electric generating plants. It's washed and screened into a few sizes. I used to haul hundreds of tons of the larger size, to be used on secondary roads, mixed with salt for traction grit for ODOT. Great for when the temps get below 20º, and salt doesn't work so well, like we had here this week. Other sizes were loaded on hopper cars, and transported to the east coast to be used in shipyards for sandblasting, and some went to companies that manufacture roofing shingles. Yep, that's what the small grit is on roofing shingles. At least in this area of the country.
