Location for a small chain box on BX?
   / Location for a small chain box on BX? #1
dragoneggs
Super Star Member
Seabeck, Washington
Kubota BX-25D, Kubota Z122RKW-42
I am wanting to add a small box, probably find or fab a metal one w/lid to store a chain, maybe some misc. tools, pins, etc. Wondering about mounting location. Here is where I am thinking. Pros, Cons, of this location on the right side vertical member of the FEL, ideas??? Also considering the BX optional tool box but I am not sure of its volume/capacity. The Kubota box mounts on the left side and I am worried that will be a little hinderance to me hopping on/off.
   / Location for a small chain box on BX? #2
I can't remember if I showed this to you. I bought a $1 crate at the Dollar Store. Fasten some Trex Decking to the bottom to level it. Then attached it to the loader arm with a zip tie. Works fine for me. I can put water there, as well as gloves, phone, or camera.
Definitely more protected there. I got long legs, I need to look at the ergonomics of that location. Thanks for sharing!
   / Location for a small chain box on BX? #4
bolt 3 or 4" pvc pipe to FEL uprights right above floorboard. I put my chains inside pipe and leave hooks on top of opening.
I like that idea.
   / Location for a small chain box on BX? #6
   / Location for a small chain box on BX? #7
I was just thinking about a box for mine to hold wheel chocks and othet stuff. I thought about where to put a box big enough for wheel chocks but the crate idea won't work for me because the brake is on that side. Hmmmm
I also like the idea you have JB for additional storage.
2000 Ford F650 Flatbed TMA (A49461)
2000 Ford F650...
2022 GTS FS35-G2 Flex Draper Header (A50657)
2022 GTS FS35-G2...
1997 EZ-GO TXT Electric Golf Cart (A50860)
1997 EZ-GO TXT...
1994 Mack CH613 Day Cab Truck Tractor (A49461)
1994 Mack CH613...
2012 Ford F-350 Mechanics Service Truck (A48081)
2012 Ford F-350...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
