hydraulic fluid
/ hydraulic fluid #1
jhaen
aurora, co
new holland ls 180
Does anyone know how to change the hydraulic oil on a new Holland ls 180,.I checked that the oil seems that needs one ASAP.
Thanks
/ hydraulic fluid #2
Thanks
Don you have an owner's manual? It should be detailed in there. Is the level low or the oil discolored?
/ hydraulic fluid
So sorry for such late response, no I don't have a manual, I ordered one online and still haven't received it, I was talking with a service tech from New Holland and he said that this model doesn't have a drain plug, and that I need to use a drain hose, that connects to the auxiliary on the front and drain it this way by pressing the pedal until empties out, I'm just afraid of messing my pump that's all, he said it will be fine but I don't know for sure, they also said that this should take no more than 30minutes.
/ hydraulic fluid #4
Are we talking about a skid steer? I am not finding a New Holland 180 tractor. I would suck the fluid out with a pump rather than do what he said and run the pump dry (if I understand what he said). I don't have a skid steer so I hope someone can help you.
/ hydraulic fluid
Yes, its a skid steer new Holland 2002 LS 180 model, the hydraulic fluid its discolored, white cream looking, I'm going to try with the pump and see how much can I get out of the reservoir, I will keep you updated.
Thanks.
/ hydraulic fluid #6
Thanks.
Oh wow, white cream looking is not good. Good luck
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
Newton Crouch Pit Stainless Steel Spreader (A64126)
Newton Crouch Pit...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
2015 Gehl V270 w/ Bucket (A63688)
2015 Gehl V270 w/...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
