New 5020c
   / New 5020c #11
Exactly, the 5020/30 are a bigger tractor than the 4047. The loader is bigger/stronger, and the operators area is bigger too. I'm actually throwing around the idea of trading up again to a cab tractor (just in the "what if" stage) and the 5020/30 would be perfect IF they came in HST.
That's what makes the decision hard for me. I won't likely upgrade unless it's also an upgrade in HP & loader, so that makes the XR4046 HST cab less attractive as a $6500 upgrade just to have the cab.
   / New 5020c #12
Also less HP, and less PTO HP not a lot but still less which I don't understand.
   / New 5020c #13
Yeah, the trend seems to be go bigger, not smaller in HP. Plus, different engines seem to have more drive line loss than others. Like, Kioti's Daedong is 49 engine / 38 PTO HP... where our Mitsu is 47/38, and our new Shibaura is what, 46/35? Although, those numbers are for the cab versions, maybe the non cab will be closer in PTO HP
   / New 5020c #14
Oh yea the cab sucks up HP!:laughing::p
   / New 5020c #15
Thanks for the info.
I can't see a cab having any bearing on driveline efficiency at all; it's just a cab, but you never know?
Weight is most improtant in a tractor for pushing/pulling duties. These new tractors are light comapred to the old Fords and Massey's. Take an old 8N, it weighs something like 7000lbs with 26hp, while my 5020C only weighs 4850lbs without the loader. Horseppower is nothing without traction for pushing/pulling chores. Mowing, running a backhoe, auger, etc is a different story; horsepower is nice.
One of the things I liked about the LS 5020 is that it had good weight to it compared with the other tractors on the market. Add the loader and loaded tires and it gets pretty good traction especially with the R-4's I got on it.
I believe there's an extra pulley on the driveline for the AC compressor ... I think that's why it's rated for less HP.
   / New 5020c #16
I have an 8N and I believe the weight of the tractor is 2,410 lbs without ballasts oils and fuel.
   / New 5020c #17
You're right. I heard that from someone and took their word as fact. Tractor Data lists them at 2410 as you indicate. Sorry for the misinformation! :)
   / New 5020c #19
True but it was 0 degrees and sunny two days ago and I was in my nice warm cab (XR4046HC) plowing and preparing a field for the spring garden. I'll suffer the slight loss. QUOTE=Guesseral;3606927]Oh yea the cab sucks up HP!:laughing::p[/QUOTE]
   / New 5020c #20
[/QUOTE]
I was just kidding.
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Nissan Forklift (A55973)
Nissan Forklift...
Evercraft 3-1/2 Ton Floor Jack, 12-Ton Bottle Jack (A59076)
Evercraft 3-1/2...
2000 Sterling L9513 Winch Truck (A56435)
2000 Sterling...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A58018)
2018 FREIGHTLINER...
