Bro-Tek 2" Wheel Spacers for our B2920 Kubota
   / Bro-Tek 2" Wheel Spacers for our B2920 Kubota #1
Howard92
South Pittsburg, Tn
B2920 Kubota, GT275 Deere
Received our 2" wheel spacers from Bro-Tek a few days ago and finished installing them on our B2920 Kubota this morning. As others have said, Richard at Bro-Tek was very easy to deal with and shipping was fast.
I had a few of concerns before ordering the wheel spacers.
Concern 1 was the studs would be threaded into the aluminum wheel spacer. I have had bad experiences with threads pulling out of aluminum. The wheel studs are not threaded into the aluminum spacer. They are pressed in from the back with spines to prevent turning and large heads which prevent the studs from pulling through.
The other concern was the inside and outside diameter of the wheel spacers would not be consistent with the factory dimensions of the wheel hole ID and the wheel flange OD. The wheels appear to be hub-centric, so I wanted the dimensions to be the same as factory. I measured the ID and OD of the Bro-Tek spacers before installing them and the dimensions were very close to factory. I would say all the dimensions were within a couple of thousandths. So, no problem there, the spacers are made to be hub-centric with the factory hubs and wheels.
The last concern is how much addition stress the spacers will put on the axles/bearings/axle housing/etc. Well it is what it is and only time will tell. I haven't read any posts where 2" spacers have cause any failures in these areas and some folk run even wider spacers; so we shall see.
Stability - that is the reason I bought them. I mainly use this tractor on some very rugged mountain land we have. I haven't tested the tractor with the new spacers up there yet, but I did take it around to some very off-camber spots in our yard. Seat of the pants verdict is they greatly improved perceived side to side stability. The off-cambers that were very uncomfortable before felt completely different with the spacers. So far, I'm very happy with the Bro-Tek spacers, only whished I had bought them sooner.
Some photos: http://www.fototime.com/inv/94049C612EEEA63
   / Bro-Tek 2" Wheel Spacers for our B2920 Kubota #2
Strange you didn't read anything, I just posted pictures of the cracks that developed on the inside of the bevel gear case!
http://www.tractorbynet.com/forums/kubota-owning-operating/282960-wheel-spacers-bx25-4.html
Sorry to hear about your failed front axle. My post is about rear wheel spacers, not front wheel spacers. I would not put wheel spacers on the front axle of a B2920. The rear axle appears to be a much more robust design than the front and even Kubota sells 1-1/2” spacers for the rear, but does not offer any spacers for the front axle.
Good luck,
Howard
   / Bro-Tek 2" Wheel Spacers for our B2920 Kubota #4
Howard92, I also have a B2920 and wanted to add rear wheel spacers for the stability issues. When I checked with my Kubota dealer he said Kubota offers 1 1/2 inch spacers but in the footnotes of his book it states that the spacers are not recommended on a 2920 if you also have a MMM. Apparently the concern is the spaced out rear wheels interfering with the rear wheels on the MMM. When I checked with Bro-Tec they said they had not heard of the issue. As you know the spacers are not cheap and I hesitate to buy them if I have to remove them to use the MMM.
Do you have a MMM with your machine and is there an issue with interference?
I have read the same posts about interference problem with rear wheel spacers and a MMM. I can't answer because I don't have the MMM..... but I would think that a couple of hours with a cutoff wheel, a mig and a can of Krylon could move those rear mmm wheels over a bit and out of the way.
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2015 Mitsubishi Outlander Sport ES SUV (A48082)
2015 Mitsubishi...
2019 Ford Explorer AWD SUV (A48082)
2019 Ford Explorer...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
1-Pallet Misc. Items (A50860)
1-Pallet Misc...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
