Adding a WI FI outlet to plug tractor into.
/ Adding a WI FI outlet to plug tractor into. #1
brokenknee
South of Moose Lake MN
I would like to add a Wi Fi outlet that I can plug my tractor into. I did a short search on the internet and saw some Wi Fi plug in outlets. I was wondering if those would handle the 1500 watts of a block heater. It would be nice to be able to "plug" my tractor in while I was still at work so I can start it once I get home.
I would also like to add a second one to plug my work vehicle into. Something with a timer function so instead of paying to have the block heater plugged in all night it would energize it a couple of hours before I go to work.
Has anyone done something like this? What are my options? What would I need and how difficult is it to install?
Thanks for the help.
/ Adding a WI FI outlet to plug tractor into. #2
That sounds like a good idea. I've wanted a way to control mine from inside the house.
Was just looking further into the plug in outlets. One I saw said there is a monthly fee. I would think there would be a system out there were no fee is required.
Was looking at the links provided, some seam to require a hub and others do not. What are the advantages to having a hub? Reading the reviews; most of the outlets hub or not seam to have a larger than normal negative comments; are these systems not all that reliable?
Has anyone done this?
/ Adding a WI FI outlet to plug tractor into. #8
The Belkins use your wifi router then you can set it to control it through "ifttt.com" which looks to be free and can setup control strategies or use it just like a remote switch this looks pretty cool.
/ Adding a WI FI outlet to plug tractor into. #9
Investing in a hub is not such a bad idea. You can control much more than just the block heater outlet. I use it to control outside lighting inside lighting and thermostats. Its nice to be able to turn on lights and turn up the heat from a remote location. Rather than investing in and maintaining a number of timers I can control the lights from my laptop, set up timers and use motion detectors to turn on multiple lights. Lots of controllers are available than can be linked to a hub and you can use a smart phone app to connect to the hub as well.
Was it easy to set up? Have you had any problems with it? What besides a hub and outlets would I need? Is there any brand or operating system you would recommend?
I know a lot of questions, thanks for the help.
Edit; any monthly cost involved? I want to avoid that.
/ Adding a WI FI outlet to plug tractor into. #11
If you wanted to do it on the cheap couldn't you get a 120 volt relay with a 5-10 volt trip, mount the wireless on/off board next to the relay and download an app that controls the board? Worst case, If the wifi board cost to much, you might have to run a low volt wire to the relay.
Cheap is good when you have the knowledge to implement it. I could probably figure it out, but the cost of wi-fi seams to be fairly reasonable now and I don't mind spending a few extra bucks to avoid the frustration.
/ Adding a WI FI outlet to plug tractor into. #13
I setteled on the Insteon system for my needs. I have been using it for several years. I have had no problems setting up the system using the plug in modules to control lights they are real easy to use. In the garage for the yard lights I wired in controlled switches which can be manually operated or controlled by the hub. I did fail a couple of the hubs, covered under warranty, when there were power spikes/failures during lightning storms. The hubs I used are no longer available and as far as I know they have been replaced with a better hub. I am currently upgrading to add more switches inside and out.
My motivation to set this up was driven by my physical condition, bad and worsening spine. I can control lights, fans and lots more sitting in my recliner with my laptop. Its nice to be able to turn things on and off at the click of a mouse button. If you already have WiFi I assume you have a router and access point. An internet connection is not needed but comes in handy to control everything when you are away from home. Being you use your own WiFi there are no monthly charges or fees needed to run the system. I also have a couple of WiFi cameras that give me a look out the front and kitchen windows so I can keep an eye on things when I am home or away.
/ Adding a WI FI outlet to plug tractor into. #15
Belkin WeMo Insight Switch Review - Watch CNET's Video Review here's CNET article this would probably be cheapest route @$49 -$59 . I'm considering going buying the light switch and testing it in the house now. I created an and account on IFTTT no charge. Belkin has free simple routines that you add to use it as a simple switch there is also a free WEMO app for android and Iphone
if you wanted a hub wemo devices are fully compatible Revolv with http://amzn.com/B00EWJQ9PK
/ Adding a WI FI outlet to plug tractor into. #18
For high watt/amp draw devices like a block heater just buy a programmable heavy duty timer and plug it into an outlet and then the heater into it Set it to trip on at a certain time and then unplug it when you get home. Simple, no setup, no wireless BS, and no problems with wi-fi not working, not working remotely, lost signals etc., etc. JMHO
I also thought about it, but then that would require me to know ahead of time when I want/need to use the tractor. I have to admit I am not always that well organized. :)
2023 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2023 CATERPILLAR...
2015 GMC Yukon XL Denali SUV (A64557)
2015 GMC Yukon XL...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
Rotary 15,000lb. 4-Post Auto Lift (A64556)
Rotary 15,000lb...
Toro Workman Utility Cart (A64553)
Toro Workman...
2009 IMPERIOAL DT7126T 12FT CUSTOM DUMP TRAILER (A66091)
2009 IMPERIOAL...
