JD 650 Battery Polarity Issue
Status
Not open for further replies.
   / JD 650 Battery Polarity Issue #81
Has the op tested the battery with a voltmeter yet? Let's get back to his need.
   / JD 650 Battery Polarity Issue #82
Agree, Need to check so he can figure out his polarity.
   / JD 650 Battery Polarity Issue #83
Vehicles are the anomaly having negative ground systems. There now.. that should elicit some responses.:)
Say whaat?? I was an electronic tech for much of my career and most electronic equipment I've worked on has been negative ground. I'll take your word on telco stuff.
   / JD 650 Battery Polarity Issue #84
Even the smaller keys system that ran on -24 volts instead of -48 are positive ground.. everything Telco is positive ground. Not that it matters. I just brought it up to see what people would say.
   / JD 650 Battery Polarity Issue #85
Sadly, the OP has not posted since the day he started this thread. A classic case of thread hijacking.
   / JD 650 Battery Polarity Issue #86
Well, I might as well jump in too. I once owned a 1973 Norton motorcycle that was positive grounded. That should at least qualify/fit the bill for as a later year. Hope that helps some. Greg
Status
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
NEW Fork Extensions (A59000)
NEW Fork...
2014 K-Z RV STONERIDGE 38FT RV TRAILER (A58214)
2014 K-Z RV...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
