273 broken frame
/ 273 broken frame #1
Bud Soda
NC
Ford 5000, 3000
So my montana 2734 frame broke into while using the loader. A little over 600 hours and I use the loader alot. I knew this was a weak link all along. I had been planing no building subframe connectors to connect the loader frame to the axle but keep putting it off. I took the loader off, removed the loader mounts and welded the frame back together. One thing for sure, I will now build and install the frame connectors before I put the loader back on. If you have a problem with the hood popping open, loader mounting bolts coming loose, etc. I would tie the front to the back ASAP.
/ 273 broken frame #2
That is unfortunate. Good thing you are handy and not scared about fixing things yourself.
I am trying to picture where you are talking about on the frame though.
/ 273 broken frame #3
That sucks. Can you show us some pics?
/ 273 broken frame #4
sounds like the same place mine broke...through the boltholes for the black loader bracket.in front of foot rest and loader valve
/ 273 broken frame #5
Due to same frame as my T 233, I'm looking forward to seeing the pictures too! On a side note, when I changed my oil this fall, I went around and checked all the frame bolts for tightness...was very suprised to find that several on the right side were loose! Mine is a 2010 model with only 140 hours on it. So, be careful out there and check the frame bolts too!
/ 273 broken frame #6
Loose loader (and wheel too!) bolts are not unusual on any brand.. You should check them upon delivery and at the 50 hour service and at 100 hours oil change and every 100 hour thereafter. They should settle down after the 100 hours. but checking at each oil change is a good idea. The bolts take a heck of a beating.
James K0UA
/ 273 broken frame
Yes broken along the bolt holes on the right side, and cracked on the left side between the bolts. Easy weld but I know it would be a matter of time before it breaks again without connecting the loader to the axle. I will take a pic of the frame connectors when I build and install them. Probably going to pick up some steel and start this weekend. I still have the old drive shaft. I probably should replace it while I am at it.
/ 273 broken frame #8
same side as mine too. mine was reluctantly replaced under warranty. it only took 7 weeks lol
/ 273 broken frame
7 weeks? Dang, I was lucky, got 6 years before it broke. :( You must have tried to move a mountain. :)
/ 273 broken frame #11
does taking the loader off when you don't need it help delaying the frame broken issue?
/ 273 broken frame
Yes, probably would. As the tractor should have a full frame to run a loader. Even when the bucket it empty it will bounce up and down putting stress on the front frame. I made a sub frame and installed it a few weeks ago. Now the tractor does not twist when I go over uneven ground with a bucket full of dirt.
/ 273 broken frame #13
Since is so easy to take the loader off the 293 I'm making it a rule. We have about 3 acres of land here and is much easier to move around without the loader specially when I'm using the rotary cutter. My tractor is getting close to the 300 hour mark and is doing great.
/ 273 broken frame #14
please post pics of your subframe connectors
/ 273 broken frame
Yeah I forgot to take a few pics before I took it back to the farm to load wood. I will try to get back down soon and get the pictures.
/ 273 broken frame #17
Anyone have a picture they can post of where the frame broke? I have noticed my loader floats side to side,about 1/2" on the mount pins. I am thinking about taking it off, just to inspect everything and make sure I don't have a problem starting.
My 5 year warranty is coming to a close soon, so I need to find all these problems soon and get them fixed.
/ 273 broken frame #18
mine broke thru the boltholes on rs where heavy steel mt bolts to frame.I could feel flex on the footpads.
/ 273 broken frame #19
Your 5yr warranty is for powertrain and might not cover the frame ... I believe TYM does a 3yr bumper to bumper, plus 2 additional years for powertrain. Just FYI
/ 273 broken frame #20
Thank you for correcting me. If a find a problem, its on me to fix it.
2020 Ford F-53 Thor A.C.E 32.3 33.5ft Class A Mobile Home (A64557)
2020 Ford F-53...
HOMEADE 101" X 25' TRI-AXLE FIVE SAFETY HOUSE (A63276)
HOMEADE 101" X 25'...
PALLET OF HOG CREAT PANELS (A64278)
PALLET OF HOG...
2006 Snorkel AB50J 50ft 4x4 Articulating Boom Lift (A64553)
2006 Snorkel AB50J...
KMC 3PT W/ 3 X 3 TOOL BAR (A64278)
KMC 3PT W/ 3 X 3...
For Sale - Brush Hog - Woods RCC42 rotary cutter
For Sale - Brush...
