Super Trac 303 Hydraulic Oil
   / Super Trac 303 Hydraulic Oil #1
Underdog57
W Michigan
LS R4041H
Quick question, is "Super Trac 303 Hydraulic Oil" good enough for my LS 4041H ? I want to use it because i have some on hand and use it in my splitter. Thanks I value everyone's opinion.
   / Super Trac 303 Hydraulic Oil #2
Is it good for wet breaks?
Yes it says "multi-service hydraulic/transmission/wet brake lubricant" on the label. I bought it at Family Farm & Home Store.
   / Super Trac 303 Hydraulic Oil #4
All I use is the TSC brand, my dealer told me any quality hydraulic oil that is good for wet brakes. I mentioned TSC and he said fine.
Ok, I think I will just use the TSC Travelers premium universal trans/hydraulic fluid. Thanks
   / Super Trac 303 Hydraulic Oil #6
   / Super Trac 303 Hydraulic Oil #9
   / Super Trac 303 Hydraulic Oil #10
Gee i wonder if there is a difference?
SuperTech 303 Tractor/Hydraulic Oil: Automotive : Walmart.com
Here is the better stuff
Super Tech Heavy Duty Tractor Hydraulic and Transmission Fluid: Automotive : Walmart.com
As you can probably see I really don't have a lot to do at work today. It's a good thing we are leaving at noon.
I wonder if there is any difference between any of the brands of non-synthetic hydraulic oils with the same spec, ie designed for hydraulic/ transmission sharing and for use with wet brakes. I use Super S Premium hydraulic oil from Atwoods at $39 for 5 gallons that exceeds the spec for Kubota UDT and several other manufacturers spec. My LS dealer said that I could use any hydraulic oil designed for wet brakes.
2012 International Prostar (A56435)
2012 International...
Hose Reel (A55758)
Hose Reel (A55758)
2017 PETERBILT 579 SLEEPER TRUCK (A58018)
2017 PETERBILT 579...
2019 GALYEAN...
2013 John Deere 27D Mini Excavator (A55973)
2013 John Deere...
Dayton 32965 80-Gallon Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
