Super Trac 303 Hydraulic Oil
   / Super Trac 303 Hydraulic Oil #1
Underdog57
W Michigan
LS R4041H
Quick question, is "Super Trac 303 Hydraulic Oil" good enough for my LS 4041H ? I want to use it because i have some on hand and use it in my splitter. Thanks I value everyone's opinion.
   / Super Trac 303 Hydraulic Oil #2
Is it good for wet breaks?
Yes it says "multi-service hydraulic/transmission/wet brake lubricant" on the label. I bought it at Family Farm & Home Store.
   / Super Trac 303 Hydraulic Oil #4
All I use is the TSC brand, my dealer told me any quality hydraulic oil that is good for wet brakes. I mentioned TSC and he said fine.
Ok, I think I will just use the TSC Travelers premium universal trans/hydraulic fluid. Thanks
   / Super Trac 303 Hydraulic Oil #6
   / Super Trac 303 Hydraulic Oil #9
   / Super Trac 303 Hydraulic Oil #10
Gee i wonder if there is a difference?
SuperTech 303 Tractor/Hydraulic Oil: Automotive : Walmart.com
Here is the better stuff
Super Tech Heavy Duty Tractor Hydraulic and Transmission Fluid: Automotive : Walmart.com
As you can probably see I really don't have a lot to do at work today. It's a good thing we are leaving at noon.
I wonder if there is any difference between any of the brands of non-synthetic hydraulic oils with the same spec, ie designed for hydraulic/ transmission sharing and for use with wet brakes. I use Super S Premium hydraulic oil from Atwoods at $39 for 5 gallons that exceeds the spec for Kubota UDT and several other manufacturers spec. My LS dealer said that I could use any hydraulic oil designed for wet brakes.
LOT: Landscape Timbers, Hand Tools (A59076)
LOT: Landscape...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A56857)
2019 Caterpillar...
2009 Ford Crown Victoria Passenger Car, VIN # 2FAHP71V79X115619 (A57453)
2009 Ford Crown...
2012 Chevrolet Express 3500 Passenger Van (A55973)
2012 Chevrolet...
33' x 25' Double Garage Steel Barn (New/Unused) (A59225)
33' x 25' Double...
2021 Polaris Ranger 1000 AWD Utility Cart (A56857)
2021 Polaris...
