1952 Ford 8N 302 v8 conversion
   / 1952 Ford 8N 302 v8 conversion #101
Found one.... hope it helps...... Dave ..... One of those is right side up..... I hope....
   / 1952 Ford 8N 302 v8 conversion #104
Sometimes...... Nothing goes as planned......
It does have an internal coil. All the drawings are showing an external coil and different color codes so we are still stymied. There are three wires coming out of the distributor, brown, black & red. These go to a connector block under the built in coil. There are 5 terminals under the connector block. We are trying to figure out what goes where? We think black out of distributor goes to ground, not sure about rest. Couldn't find any good diagrams at mallory or google that match our distributor/coil combo. Wish I could find the harness we lost.
We have the following markings on the cap:
+ which we think goes to ignition hot +
- goes to ground on block
GRD black from distributor
COIL brown from distributor
BATT red from distributor.
Not sure if this is wired right, tried other set ups, they didn't work either.
Grounds are testing OK. Power is coming into +
No spark to plug as we crank it.
Maybe distributor is faulty?
Does it have an internal coil... You may need an external coil.... and resistor... Now you know all I know..... almost nothing...
Dave
   / 1952 Ford 8N 302 v8 conversion #106
Wrong rotor.... rotor not making contact... cracked rotor... wrong cap.. I'm lost here......
Dave
Rotor, coil, distributor came as a boxed set so the should be matched. Brand New. You feel our pain?
   / 1952 Ford 8N 302 v8 conversion #109
2016 KUBOTA RTV-X900 UTV (A51242)
2016 KUBOTA...
2012 International Day Cab Truck Tractor (A50323)
2012 International...
UNUSED INDUSTRIAS AMERICA F08 - 8' LAND LEVELER (A50459)
UNUSED INDUSTRIAS...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
Year: 2020 Make: Cadillac Model: Escalade Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 73,021 (A50324)
Year: 2020 Make...
