1952 Ford 8N 302 v8 conversion
   / 1952 Ford 8N 302 v8 conversion
Working on my 8N Awesome Henry 302 V8 conversion. Still have not got the motor running.
Plan was to start it today but we ran into what we thought might be a ringgear problem even though Don at Awesome Henry says this has never caused a problem and all his flywheels are built this way.
Starter howls - the awesome henry ringgear has the almost square cut towards the starter drive gear.
Shouldn't the beveled side of the ringgear face the starter drive gear?
Could that be the source of the howl?
This happens whether the motor is bolted to the tranny or not so the eliminates the pilot bearing.
Happens with old and new starter. Starters run quiet off the tractor.
No bolts are hitting anything and motor turns freely by hand with the plugs pulled.
Problem Solved!!!
I have the 164 tooth manual flywheel with the auto old style starter and I just figured out the problem. The kit included a 3/8" spacer to use the auto starter on the manual flywheel. Turns out I needed a 5/8" spacer. I tested my theory with a couple of washers and the howling went away. The inside of the bendix was touching the front of the flywheel when it spun out in the active mode. Nothing that 6 hours of debugging, disassembly, reassembly, repeat 5 times couldn't solve.
Turns out the cut of the ringgear teeth was not the issue.
   / 1952 Ford 8N 302 v8 conversion #92
Sweet! Overcoming some frustration adds to the feeling of accomplishment. Looking forward to seeing some video of it moving.
   / 1952 Ford 8N 302 v8 conversion #93
to bad the kit didn't have that info!
   / 1952 Ford 8N 302 v8 conversion #94
Problem Solved!!!
It's a great feeling of satisfaction, when you can figure stuff like that out.... Genius, pure genius........
Dave
Awesome Henry V8 302 conversion Starter Problem and fix
No genius here, some say I am just very persistent!!
Here are the pix of the problem and the fix.
Note: I also enlarged the top mounting hole by 1/16" on the starter itself as the starter drive gear was awfully tight to the ring gear. This allowed me to pivot the starter just a smidgeon away from the ring gear.
Thanks for all the support and assistance.
Merry Christmas to everyone and to all an "N" night
Oh Oh, can't get spark out of Mallory 8555101C billet distributor and it did not come with a wiring diagram, it is meant for a car connector. Anyone got any knowledge of these?
   / 1952 Ford 8N 302 v8 conversion #97
Does it have an internal coil... You may need an external coil.... and resistor... Now you know all I know..... almost nothing...
Dave
It does have an internal coil. There are three wires coming out of the distributor, brown, black & red. These go to a connector block under the built in coil. There are 5 terminals under the connector block. We are trying to figure out what goes where? We think black out of distributor goes to ground, not sure about rest. Couldn't find any good diagrams at mallory or google.
Dave
   / 1952 Ford 8N 302 v8 conversion #99
I couldn't find ANY diagrams or schematics... Are there any symbols where the wires enter the housing...
   / 1952 Ford 8N 302 v8 conversion #100
Found one.... hope it helps...... Dave
Next post.....
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2016 Volvo A25G 20CuYd Articulated Dump Truck (A49346)
2016 Volvo A25G...
UNUSED RAYTREE EXCAVATOR MULCHER (A50460)
UNUSED RAYTREE...
2003 STERLING ACTERRA 11FT FLAT BED (A51222)
2003 STERLING...
2006 John Deere 310SE 4x4 Loader Backhoe (A49461)
2006 John Deere...
