PTO shaft to mower stuck on tractor
/ PTO shaft to mower stuck on tractor #1
copperman1948
Ocala, FL
John Deere 5410 with 540 front bucket is my work tractor. Have a 47 J.D. Model A, have 4 Farmalls
I have a 5410 John Deere tractor with a 10' wide mower. The mower pto shaft has become stuck on the tractor's pto shaft. I have remove the standard release pin completely. I can see all the way through the hole where the pin
holds the mower pto shaft on the tractor and have confirmed the release pin is NOT the problem. Have use two pry bars to try to pry the mower shaft off while pulling on it with a 2000 pound come-along.
Does anyone have any suggestions?
/ PTO shaft to mower stuck on tractor #3
CRC Freeze Off - No turning back once you try it.
ZZZ2D1
Am not aware of CRC. Can you tell me what it is?
newbury,
If you get my responce twice, forgive. I have not tried heat as I did not want to burn out the seal on the tractor, but looks as though I have no choice.
/ PTO shaft to mower stuck on tractor #7
I think I'd disassemble the u joint and apply a good two jaw puller.
/ PTO shaft to mower stuck on tractor #8
newbury,
I wonder if you pushed a big bar of steel cross-ways into the U joint and whacked the end down in the opposite direction that the PTO shaft would normally turn would this possibly free up the galling that may have occurred between the PTO stub and the U joint coupler. Just an Idea, and would not take long to try it.
/ PTO shaft to mower stuck on tractor #9
Can you get a chain/hook on the PTO shaft, maybe through the u-joint with something like a bar to spread the load, attach that to something massive, and try using the tractor to pull it free?
/ PTO shaft to mower stuck on tractor #10
most auto parts stores have it, what it does is lowers the temp really fast and is about 6 bucks a can . it is made by crc and is called freeze off.
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A59228)
2025 GIYI GY-SZYMJ...
2000 Kenworth Tri-Axle Dump Truck (A59230)
2000 Kenworth...
2013 FORD F-350 (INOPERABLE) (A60736)
2013 FORD F-350...
2025 Swict 66in Bucket Skid Steer Attachment (A59228)
2025 Swict 66in...
2011 INTERNATIONAL 4400 (A60736)
2011 INTERNATIONAL...
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
