I have an MF35 with the 23C diesel, its developed a problem where air seems to be getting into the injector pump, causing it to die and I'm continually having to bleed the air out of the pump to get it going again. It started happening about a week or so ago, and has gradually got worse - today I cant do a lap of the field with the hay mower without it cutting out and needing to be bled again. I cant work out where the air is coming from, it has a full tank of fuel and I cant see any obvious leaks round any of the lines or connections. It only appears to become a problem at revs under load (I'm working a mower at 540 pto rpm). I've noticed a couple of cork gaskets on the injector pump which are badly degraded - could this cause the pump to draw in air? I would have thought everything would be under positive pressure and I'd more likely get a fuel leak - but I'm no injector pump expert! Any help would be much appreciated!
