3-Point Hitch Correct hydraulic oil for MF35 utility
/ Correct hydraulic oil for MF35 utility #1
AKDavis
Orleans, VT
MF 35
I have an older (maybe a 53) MF35 utility. The 3point hitch usually won't come up at all. The gear case oil seems to be frothy as if it had water in it. Would that cause this problem? What what I replace oil with?
/ Correct hydraulic oil for MF35 utility #2
If it's a MF35, I doubt it's a '53!
A good UTF (Universal Tractor Fluid) is adequate for an MF 35. Permatran is the spec MF replacement fluid but it tends to be spendy. DO NOT USE HYDRAULIC FLUID.Remember the final drive is also in the hydraulic sump so it needs a transhydraulic fluid.
I'd susupect a problem with the control valve or the linkage might be causing your lift problem.
Thanks for the info, the serial# is: UGM655001753, thats where I got the 53. I'm going to change the fluid anyway and see what happens. Thanks again and have a great holliday
/ Correct hydraulic oil for MF35 utility #4
I don't know where you got that serial number but the first Massey Ferguson 35 was made in 1960 and the first serial number was 204181. It was preceeded by the Ferguson TO-35 which was was first made in made in 1954 and had a starting serial number of 140001. ( Ref. Yesterday's Tractors research & Info Section-Serial Numbers)
Your number looks like a casting number to me.
/ Correct hydraulic oil for MF35 utility #5
Froth means water in the hydraulic fluid. Need to drain the old stuff and replace.
That number is a casting number. On my 1964 MF135 diesel the serial number tag was located in the area around the battery tray. I had to remove the battery to find it.
Good luck.
Thanks for the info. I changed the oil, the 3point hitch arms are now loose, with the engine running I can lift them up and down and they will stay up but it feels spongy. Is there a way to bleed this system? The number I got is on a plate on the left side of the dash,it sure looks like a serial#
/ Correct hydraulic oil for MF35 utility #7
It will bleed it self, but its important to replace any rubber boots around gear level to prevent water from coming inn.
Thanks, I'll do that.
/ Correct hydraulic oil for MF35 utility #9
Up and down, up and down, up and down till it gets hard....................... the tractor's hydraulics. I had the MF 35 with the 3 cyl Perkins diesel. A real tugger. Sold it because the clutch was too hard on my injured left knee and I needed power steering.
Mark
Thanks, it did bleed itself and is working great. Thanks for the info. Mine is gas and it has the shuttle shift which works great for plowing snow.
Pat
2022 CATERPILLAR 307.5 EXCAVATOR (A62129)
2022 CATERPILLAR...
MMS MS750 Remote Control Lawn Mower (A60463)
MMS MS750 Remote...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
