block heater for 25 HP lai dong engine?
   / block heater for 25 HP lai dong engine? #1
Lodi
Member
walworth WI.
Lu Zhong
Does anyone know where to get one?
   / block heater for 25 HP lai dong engine? #3
Affordable or Circle G will probably know which heater will best fit your tractor as far as using an in line coolant or casting plug style Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
Jinma Tractors, Jinma Tractor Dealers, Wood Chipper Dealers Circle G
although I would suggest the inline , once that freeze plug is removed you are committed, although that is the style I have installed on my chinese tractor...
   / block heater for 25 HP lai dong engine? #4
Mine came with an inline rad hose heater which I'm glad it's there! 1 hour and she is warm to go. Been getting -45C windchills last 3 days; ouch! Good thing I didn't use the tractor!
   / block heater for 25 HP lai dong engine? #5
Hi gabmux. As others have said the inline heaters are a great alternative if you don't end up going with the block heater. They are also easily replaced if it happens to burn out on you. You will need one that fits a 1.5" hose. Let me know if I can help you.
Just did a quick search for you and not much comes up on actual block heaters. Seems that most use the inline type and most also reccommend against the magnetic and dipstick type.
   / block heater for 25 HP lai dong engine? #6
I have a brand new Nortrac (Foton) 25HP tractor that was having trouble starting in the cold. I was back and forth with Nortrac and was convinced there was a problem with the glowplugs. Nortrac kept giving me small fixes, none of which seemed to help much. When I admitted that I was not using the coolant heater as I have no power in the shed where I keep the tractor, the service manager highly suggested I use it. I ran a cord to that building and plugged the heater in overnight. The next morning the machine started within 2 seconds of cranking. I would highly recommend one of these as a inexpensive easy fix.
   / block heater for 25 HP lai dong engine? #7
Mine does the same now that I have the glow plugs fixed; I use a 200w magnetic block heater though. Not a big fan of the inline coolant heaters.
   / block heater for 25 HP lai dong engine? #9
Magnetic block heaters are worthless. I own 2 or 3. Nothing close to a block or lower coolant hose heater.
Chris
   / block heater for 25 HP lai dong engine? #10
What does a measly 200W stuck to the side of the block do ?
200 watts = 11.4 BTU's/minute. So, if it's turned on for 30 minutes... Well, you're smart enough to do the math.
I used to use the magnetic heaters on the skid steer hydraulic reservoir before I switched to multi-vis hydraulic oil. Worked very well.
2008 International 8600 T/A Day Cab Truck Tractor (A48081)
2008 International...
SHOP MADE PROPANE TRAILER (A50854)
SHOP MADE PROPANE...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2016 CHEVROLET SILVERADO 2500 HD CREW CAB TRUCK (A51243)
2016 CHEVROLET...
PAIR OF 29 FT PIPE RACKS (A50854)
PAIR OF 29 FT PIPE...
2007 WABASH 53FT DRY VAN TRAILER (A51222)
2007 WABASH 53FT...
