block heater for 25 HP lai dong engine?
   / block heater for 25 HP lai dong engine? #11
most of the heat is lost to the air when stuck to the side of the block. Considering the thermal mass of an industrial or farm engine. 200W will not warm it unless you think 32F is bitter cold.
A 200W heater under an oil pan or tank will do a half decent job in some circumstances.
Can't beat an immersion heater that warms the coolant inside the engine and gets the heat right to the combustion chambers.
Rhino FS15 Flex-Wing Rotary Cutter - 15 Ft Heavy-Duty Brush Hog for Pasture and Roadside Mowing (A51039)
Rhino FS15...
2012 MITSUBISHI FUSO SINGLE AXLE DUMP TRUCK (A51222)
2012 MITSUBISHI...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
TEST YOUR BID BUTTON! (A51242)
TEST YOUR BID...
2015 INTERNATIONAL 4300 26 FT NON CDL BOX TRUCK (A51219)
2015 INTERNATIONAL...
CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A50458)
CATERPILLAR D8T...
