Max 28 tool box
/ Max 28 tool box #21
This is a MAX 25? Where did you get the retractable seat-belt setup? Mine is constantly getting lost under the seat. -J
My Max 28 I had and the 25 I looked at buying originally both had the retractable seat belts.
/ Max 28 tool box #22
-J
Great question do tell; I was wondering that same thing. I added a lanyard to the buckle-end of the seat belt and secured it to the PTO lever; I kept the lanyard long-enough to allow the buckle to fit snugly. I reach for the lanyard at the PTO now. On the other end, I drape the belt over the arm rest or set it in the R/S cup holder.
/ Max 28 tool box #23
This is a solid idea as well. No arm rests for me, but the lanyard is a great idea. I'll be honest and say I'd wear my seat belt more often if i didn't have to fumble with finding it.
And TBT... what is the cup holder you speak of? I didn't think Mahindra knew what they were.....
-J
/ Max 28 tool box #24
/ Max 28 tool box #26
Not sure about the 28, but the only cup holder on my 25 is between my legs.
-J
A couple white pine 1X4s (on end & side by side) easily slides under the seat (with minor milling) and stays-put, to form a rectangle protrusion which can be shaped into a cup-holder or small center console using 90 degree 1X4s and screws.
A 13" L assembly should protrude forward and out 4" while not interfering with operator functions.
When/if I get my tractor back, I will take and post the pics; and spend less time on the internet.....
/ Max 28 tool box #27
I'd be interested in seeing what you cooked up. I've been looking at different clamp on style options for a while now. Best I've found so far is at Duluth Trading Co. They call it the robocup. Looks pretty sweet.... Link below.
Cupholders - Robocup - Duluth Trading
-J
/ Max 28 tool box #28
-J
It is standard i beleive because on the turning seat for backhoe i got with it
/ Max 28 tool box #32
Looks good! I had to laugh while reading the string.... Any carbonated beverage that goes flat in any cup holder is simply not being drank fast enough..... am i right?
Pretty much.
/ Max 28 tool box #33
I'm thinking of a 3016; not sure what the differences in the tractors are...no cup holders on the Max 28?
I use the "cup-holders" to hold pins, nails, gloves, rags, and other small items.
My armrests are a dream!
$40.00
http://www.tractorbynet.com/forums/mahindra-owning-operating/280606-armrest-3016-seat.html
The lanyard for the seat belt buckle is visible in the one picture.
Has anybody tried to fit the 3016 fender extensions on the max 28. When I went to the dealer this week the fenders look similar in size but I never took measurements?
/ Max 28 tool box #34
Hey Sfrankland love your solution for a toolbox holder on your 3616...how did you attach the piece of sheet metal to the tractor and where did you attach it to? Thanks for the GREAT idea!!!
/ Max 28 tool box #35
I picked up a small stainless box from HB. Made a platform that goes in between the 4 inside bolts on the rops. Still working on way to add a cup holder and parts try as a all in one unit. But it works great and no modifications to the tractor. Seat does not hit even when all the way back.
/ Max 28 tool box #36
View attachment 507438View attachment 507437View attachment 507439View attachment 507440
OK, that's really a lot nicer than the $10 Red Painted tin foil "tool Box" I slapped on and then zip tied a cup holder to the ROPS. The Box supposedly was made in the USA.
10222 (A56858)
10222 (A56858)
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
2018 MACK PINNACLE (A60736)
2018 MACK PINNACLE...
New/Unused Landhonor Mini Skid Steer Rock Grapple (A61166)
New/Unused...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
