john deete 112 hydraulic lift question
   / john deete 112 hydraulic lift question #1
neontetra
woodstock, il
gilson hydro 16
I just bought an old JD 112 with hydraulic lift from my neighbor. The movement of the hydraulics is really slow. Is this normal for JD hydraulics? My Gilson hydraulic lift is powerful enough to clear a plugged snowblower by lifting and dropping the unit. The JD motion is barely perceptible, and you have to watch to make sure it is all the way down.
   / john deete 112 hydraulic lift question #2
is it possible you have water mixed in with the hyd oil and going slow during freezing weather?......maybe to wrong hyd oil (too thick).......or have any hoses on the control valve changed recently? (possibly crimped too tight)
Thanks wdchyd,
So you think the hydraulics should actuate more rapidly, like the gilson I have? The hydro fluid is probably 10+ years old.
   / john deete 112 hydraulic lift question #4
Not sure about your machine, most move fairly fast......Maybe someone here can time one for ya
   / john deete 112 hydraulic lift question #5
The speed of the cyl is dependent based on the GPM.
What is your GPM and size of your cyls?
   / john deete 112 hydraulic lift question #6
I did not know that JD put hydraulic lift on the old 112's They either had mechanical or electrical lift. If electric lift it was supposed to have some very beefy helper springs to lift the snow blower.
Note: Someone may have added a hydraulic lift.
   / john deete 112 hydraulic lift question #7
my father has a 110 and a 112 both patio series, and both with factory hydraulic lift. pump tank and valve is a self contained unit thst bolts to the top of the kohler.
   / john deete 112 hydraulic lift question #8
if i recall correctly it takes about 2-2.5 seconds to lift the snowblower from the ground to the stops.
   / john deete 112 hydraulic lift question #9
Here's some parts photos of the JD hyd lift system
2014 Ram 1500 Crew Cab Pickup Truck (A55788)
2014 Ram 1500 Crew...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
2018 John Deere 325G (A47477)
2018 John Deere...
2013 Chevrolet Traverse AWD SUV (A53424)
2013 Chevrolet...
CAT 973 (A47384)
CAT 973 (A47384)
2008 Ford E-350 Versalift Vantel29N 29ft Bucket Van (A55788)
2008 Ford E-350...
