Weld prep routine
/ Weld prep routine #1
OutbackL130
chickamauga
L130, 420
How do you prep fresh new metal from the steel mill before welding?
/ Weld prep routine #2
I usually hit it a bit with a wire wheel. And if that does not look shiny enough for me, I use a flap wheel on the 4 1/2 inch grinder
James K0UA
/ Weld prep routine #3
I am far from being an expert.
I wire wheel it for SMAW and O/A.
I wire wheel followed by 4.5 inch abrasive grinder pad for TIG.
/ Weld prep routine #4
Yes definitely the bare shiny surface fior TIG.. but the duller surface is fine for SMAW. I guess he didn't really say what process did he?:)
/ Weld prep routine #5
I just buff to shiny.. remove dirt rust etc.
/ Weld prep routine #6
Well all you get in construction is a quick wipe off with your glove! If the mud is still to thick to get an arc going, wipe it again. :D
/ Weld prep routine #7
Yep , grind off the mill scale with a flapper disc or wire wheel. Then wipe down with a quick drying solvent like acetone , paint thinner . This is for ASME code welding.
/ Weld prep routine #8
With 6010 rod I rap it with a hammer to knock the loose rust off and then commence to weld it.
/ Weld prep routine #9
Well to the pro welders, I mean those who do / did it for a living (shield arc) are you being serious that for stick at construction sites you really don't clean the metal beyond just being clean (knocking the scale off, rust off). I know for Mig and Tig clean is necessary (I assume for current flow) but stick seems to be the "just as long as you can touch metal you will be fine".
/ Weld prep routine #10
Only for code welds! But not all the time! When we built the West Seattle bridge in the early 1980s I was splicing 24-inch pipe pile right on East Marginal way, 100% X-ray. It was pouring down rain, water was running down the inside of the pipe and out the joint. The welding inspector was watching me weld. I'd make a pass, and have to grind out two because of all the pins holes. I was standing knee deep in water inside a cofferdam. I asked the foreman to send someone up and put a cover over the pipe to stop the water. He replied "I thought you said you could weld"! I went back down in the cofferdam to continue welding, the inspector said to me I think I'm going to shut you down. I said good idea, but they can get some one else to make these welds, I'm out of here!:mad:
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
Woods DS8.50 (A60462)
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
2020 Case 5550 Trident (A61307)
2020 Case 5550...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Kuhn FC400RG (A60462)
