Flyerdan, I would like to eliminate the battery in the dump trailer. My knowledge of auto elect. is limited so I wasn't sure about the size breaker and solenoid. Should they match? I am not sure if dump motor draws 30A or 100A or 10A. Wire on dump battery looks to be 4ga which is why I got 4ga to run from truck. Of course since then I have found that due to the length of run, the wire probably should have been 2ga or 00. Mute now since already bought the wire. The breaker and solenoid idea came from my concern to protect the truck's electronics. Not in a rush to do this, but would like to do it well and safe (Safe for the truck also). Truck only 3 mos old and don't want any issues.
this is a quote from tommy lift, the waltco page also listed 200 amps max. I guess the breaker is of a time delay type that will carry more than its rating for a short time before it opens.
The Tommy Lift "Mini" model is available for all one ton pick-up trucks.Now available with aluminium platform
Tommy Lift Series 1000 Model Mini.
Capacity
- The series 1000 Tommy Lifts are electro-hydraulic tail lifts capable of raising and lowering 500kg
Mounting
- The Tommy Lift is designed to suit one ton pick-up trucks through to 7.5 ton GVW drop side trucks, flat beds, tippers,
Lutons and box bodies.
- Tommy Lifts are designed so that spare wheels can remain in original position and tow bars can be used.
Loading Platforms
- The standard loading platform is constructed in 12GA (2.6mm) steel with a fold out extension. Platform remains flush
with top of truck bed and will not obstruct driver's view.
Mechanical Features
- All critical components are fully enclosed in main frame of tail lift providing protection from elements and damage. Easy
access for servicing.
- Electro-hydraulic power unit which only runs when lifting.
- Pump: 12 volt DC unit / 205 amp draw / 3800psi pumping.
- Bushes with grease nipples on all pivot points for long wear and ease of maintenance.
- Zinc plated cylinder ram
